MAP EF-series Turbochargers results thread
Old Oct 25, 2011 | 04:12 PM
  #256
getsideways's Avatar
I havent seen it on the EF3 yet , the best ive seen on my Stock block on pump was 470 something , Im sure if i would tried i coulda gotton closer at higher boost.
The EF4 would probably hit that easily.
Old Oct 25, 2011 | 07:42 PM
  #257
Levar's Avatar
Veteran: Army
Originally Posted by getsideways
I havent seen it on the EF3 yet. The best I've seen on my stock block on pump was 470 something. I'm sure if I would tried I could have gotten closer at higher boost.
Interesting. If I can make 425whp on pump/91 I would be pleased. Pump/91 would be my emergency fuel of choice as I have E85 all over southern Arizona and 500whp will be easy to achieve.
Old Oct 26, 2011 | 05:37 AM
  #258
The less aggressive track day tune was around 430 440 and was able to run on 91\92 with no knock
Sounds like you picked exactly what you wanted !
Old Oct 26, 2011 | 08:01 AM
  #259
juanmedina's Avatar
Will this turbos ever get flow tested? According to the original turbo release thread it was supposed to be done a few months ago
Sweet turbos
Old Oct 26, 2011 | 08:20 AM
  #260
ChrisCarey's Avatar
I'll be honest its not on the top of our priority list at this time, we plan to let the dyno results speak for themselves until we find some free time to pursue it.
Old Oct 26, 2011 | 10:04 AM
  #261
juanmedina's Avatar
But its hard to know what is the actual flow of turbo using dyno sheets since every setup, dyno, conditions etc etc is different. Would you say that the EF2 is about a 52lb/min turbo?
Old Oct 26, 2011 | 10:06 AM
  #262
murlo26's Avatar
I think most people just care what a turbo is capable of in the end. Flow numbers are nice, but for instance the FPblack is rated at 68lb/min but people go over that number all the time.
Once we get more results everyone will know what the turbo is capable of on different setups.
Old Oct 26, 2011 | 10:26 AM
  #263
ChrisCarey's Avatar
I think 51-52lbs/min would be an accurate estimate.
Old Oct 26, 2011 | 10:28 AM
  #264
RazorLab's Avatar
That would make it right inline with the BBX Lite. Which I believe is right what you where aiming for correct?
Old Oct 26, 2011 | 10:36 AM
  #265
ChrisCarey's Avatar
We were aiming for 400 on pump and 450 on E85 with some room to spare and I think we've accomplished just that Is the BBX lite a comp wheel only upgrade or both wheels?
Old Oct 26, 2011 | 10:41 AM
  #266
RazorLab's Avatar
It's both wheels and I have logged 52-53lb/min at 26-27psi
I'm not starting a fight here. I was mearly asking the question. The curves make it look like the same market as the BBX Lite. More options are always good.
Old Oct 26, 2011 | 10:57 AM
  #267
ChrisCarey's Avatar
Don't get me wrong sir I didn't feel you were trying to start anything, I'm just not as informed on the CBRD offerings as I should be so I had to ask
Old Oct 26, 2011 | 11:57 AM
  #268
EnjoyDriving's Avatar
How about EF3? What is the "guessed" flow on that? I would like to use that to compare to HTA Green and BBK-Full.......I'm currently torn in between these beasts
Old Oct 26, 2011 | 12:06 PM
  #269
ChrisCarey's Avatar
My best guess would be 60-61lbs/min on the EF3 and 71-72lbs/min on the EF4. The EF3 has a bit larger comp wheel than the HTA green and I'm afraid I once again don't have enough info on the CBRD turbo to compare
Old Oct 26, 2011 | 03:20 PM
  #270
ChrisCarey's Avatar
More EF4 results here: https://www.evolutionm.net/forums/9700862-post1.html
Originally Posted by rawkus
Hello all,
I wanted to share my results (ignore A/F ratios, not reading accurately on this pull).
Mods-
2.4L Manley Billet Crank 4G64
10.5:1 Manley Pistons and Rods
Manley +1 Valves, no porting
MA Performance Rev 3 Intake Manifold
MA Performance Tubular Exhaust Manifold
MA Performance o2 Eliminator with External Gate
Full Blown Cast Throttle Body
Kelford 272s
ETS Intercooler
3" Vibrant High Flow Cat
3" Borla Full Exhaust
