MAP EF-series Turbochargers results thread
Old Jun 3, 2012 | 08:00 AM
  #751
Craig King's Avatar
Originally Posted by wanguru
What is going on in this picture? Looks like there's a TiAL external WG bolted to the turbine outlet???
Old Jun 3, 2012 | 08:09 AM
  #752
Levar's Avatar
Veteran: Army
I believe that is the old MVS that bolts up to the O2 housing if I am not mistaken, my friend. Maybe the downpipe was not installed before the picture was taken. Interesting...
Old Jun 3, 2012 | 08:27 AM
  #753
Craig King's Avatar
Unless I'm seeing something wrong, that external WG is completely replacing an O2 housing??
And what is 'the old MVS' ?
Old Jun 3, 2012 | 08:36 AM
  #754
getsideways's Avatar
Its MAPs external WG downpipe, when used along with the standard Internal WG provides very Linear boost control on a stock frame turbo. Shame its quite hard to fit in there...
Old Jun 3, 2012 | 10:20 AM
  #755
ChrisCarey's Avatar
Great results! And there is a 3" exhaust tube under that wastegate somewhere, just a weird angle
Old Jun 3, 2012 | 10:45 AM
  #756
wanguru's Avatar
Here is a better angle.
Old Jun 3, 2012 | 03:08 PM
  #757
Make sure you put some heat wrap on your AC line, otherwise it will melt through if you pisspound the car.
Old Jun 3, 2012 | 07:16 PM
  #758
Craig King's Avatar
Ok, that makes a lot more sense now. I see what is going on.
Thanks
Old Jun 4, 2012 | 07:56 AM
  #759
VGergo's Avatar
is that harm the spoolin or the twinscroll ? looks like cool !
Old Jun 4, 2012 | 08:19 AM
  #760
ChrisCarey's Avatar
You'll notice that he still has his internal wga hooked up as well to maintain the twin scroll effect
Old Jun 4, 2012 | 09:04 AM
  #761
wanguru's Avatar
Correct. IWG (25lb actuator) runs direct to boost source and EWG to 3-port controller (GrimSpeed). Full boost by 4100-4200 (on 2.3 liter) with very linear control up top. Maybe a bit of an overkill but definitely worth 25-30whp up top.
Old Jun 4, 2012 | 09:06 AM
  #762
wanguru's Avatar
Thanks for the tip...
Old Jun 4, 2012 | 10:21 AM
  #763
Revobasher's Avatar
Quick update.. .I have about 3k on my build now and this turbo is the shiz.. yeah it spools a little late (most larger turbos do) but once it hits look out! It sounds killer as well!
Well done MAP.
Old Jun 4, 2012 | 10:32 AM
  #764
Kracka's Avatar
Awesome!
Anyone have more miles on MAP turbos than me? 14k miles and counting...
Old Jun 4, 2012 | 10:53 AM
  #765
wanguru's Avatar
Also don't forget the customer service that comes along with the purchase.
