MAP EF-series Turbochargers results thread
It is a road race car and Im trying to make the motor live. We did crank it up to 30psi for a few pulls and it made over 500, we couldn't go any higher because we started to run out of fuel (FIC 1450's).
You pretty much have the same setup as I am building currently with the exception of me using a MAP 2.3. Nice numbers
Look at any of the ef3 graphs and thats about what you will see. That and it depends on tuners being they all tune differently. Just depends on your mods and your hp goals.
Just bought my EF3
thanks again Nate for all your help. I wont be back form Iraq till Oct but can i post my results from my set up on this thread?
EF3 with 3inch surge housing and fully ported
Gsc S2s w.spring and retainers
and ill pry be running pump 92 for now i cant wait to get back and put this thing in
thanks again Nate for all your help. I wont be back form Iraq till Oct but can i post my results from my set up on this thread? EF3 with 3inch surge housing and fully ported
Number of people were looking for EF2 results, so here's a quick graph from me. This is by no means a finished tune, so numbers will definitely change by the time I'm done. Just throwing this one up to give an idea. Also fixed a boost leak tonight so spool will get better. This is on 94 octane.
Most noteworthy mods are in my sig. Not mentioned is that I have a built 2.0 with 9.1:1 CR.
