MAP EF-series Turbochargers results thread
Need some input, guys.
Does the EF4 really spool as slow as it appears on some of these graphs? I'm going to be sending my IX turbo out for an upgrade (the sky is the limit), but would like to use a MAP product if it fits the bill nicely. Is there any wheel clipping options or anything you guys are doing to get the turbo to spool faster? If I'm not seeing full boost by 41-4200 I really don't see the lag worth the extra power up top.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Look at Levar's dyno graph. He has a pump graph up with a 2.4L and EF4. If I remember correctly it wasn't that bad for spool.
Steven David - He is close to me and you Bob. Do you want me to see if he can come hang out with us one day and take you for a ride in his car? He has a 2.4L and a EF4.
Mine does being I have a different cold side. I have one of the first ef4's when they beta tested so mine does yes. Doesn't help I am on stock block and my tq curve is drawn out to help save the motor so yes mine seems laggy. Chris stated earlier in another thread they changed the cold side to a different cover and it helps alot with the turbo smart wga.
And Adam, that would be fantastic.
Any thoughts?
Any thoughts?
300ft/lbs around 3800 and 400ft/lbs around 4200 makes for a fun ride!
.And agreed about the TQ. I'll be in contact
