MAP EF-series Turbochargers results thread
Old Jun 6, 2012 | 01:35 PM
  #781
wanguru's Avatar
Originally Posted by mrfred
Lowering base pressure will help, but won't be enough. A boost-a-pump might get you there all by itself with a DW300, but for optimal performance, lowering base pressure and/or running a larger diameter fuel supply line are desirable.
Yeah, definitely don't wanna start losing pressure up top "trying" to push a single pump. Will keep a close eye on IDCs when I start to dial E85 in. May end up just biting the bullet and get a double pumper... Thanks for your input.
Old Jun 6, 2012 | 01:49 PM
  #782
Kracka's Avatar
You could always look towards a Walbro 400 instead of a double-pumper.
Old Jun 6, 2012 | 01:51 PM
  #783
murlo26's Avatar
I agree with Kracka.
Coming from a guy with a double pumper, if you can avoid using two pumps do it. However i view the Boost a pump as just as reliable (or unreliable depending on how you look at it) as a twin pump.
My next upgrade will be a big *** weldon, external style.
Old Jun 6, 2012 | 02:15 PM
  #784
wanguru's Avatar
Thanks for the tips. I really don't wanna go too far off topic on this thread but I am sure that MAP guys will be taking care of my fueling needs
Old Jun 6, 2012 | 02:28 PM
  #785
wanguru's Avatar
Originally Posted by getsideways
Im kinda proud of this thread, Went back to page 1 and looked at the results that are there and easy to find, Makes buying a MAP turbo much easier.
Thanks for everyone contributing as well, And nice results megatron, that was at relatively low boost for an EF4, Im sure if you want more power you will find it.
Thanks for starting this thread as it has gotten a lot of folks (including myself) excited about the EF series!
Old Jun 6, 2012 | 02:48 PM
  #786
tscompusa's Avatar
has anyone tried the walbro 450LPH yet?
Old Jun 6, 2012 | 04:55 PM
  #787
getsideways's Avatar
I assume your talking about the E85 version of the wally 400? Is that what their calling it 450?
Thats what i am running currently i got it a few weeks ago after it was released.
So far supporting low 500WHP range on stock rail, lines, wires, regulator. I havent tried high boost on it yet.
Old Jun 6, 2012 | 05:14 PM
  #788
tscompusa's Avatar
yes. its advertised as being 450LPH now.
nice let me know how it is on high boost please.. it looks like a nice alternative.
Old Jun 6, 2012 | 05:27 PM
  #789
Should be opening up the turbo soon here, Will be posting back with results.
Old Jun 6, 2012 | 09:34 PM
  #790
wanguru's Avatar
Please keep us posted...
Old Jun 10, 2012 | 03:25 PM
  #791
Kracka's Avatar
https://www.evolutionm.net/forums/ev...mp-gas-16.html
I need cams
Old Jun 10, 2012 | 03:51 PM
  #792
laramie_05MR's Avatar
Cams? Didn't you complain about the driving manners of your 9?
Old Jun 10, 2012 | 04:17 PM
  #793
evotuner04's Avatar
15 Year MemberLikedLoved
Agreed, I went through this thread when I was trying to decide what turbo I wanted and I couldnt be happier with it, its just flat out nasty
Old Jun 10, 2012 | 08:04 PM
  #794
Levar's Avatar
Veteran: Army
Originally Posted by tscompusa
afr uptop was 11.7-11.8.. it was just a base e85 pull. much more in that car once i straighten the boost curve and do minor tweaks.
after he adds another pump ill make that curve 32 across and he will prob make around 570 at 32psi.. which should put the car well over 130's in 1/4. (i just went 128.69 with 511 in vd)
This sounds scary, my friend.
I like simple set ups. If the larger single can get me there, count me in.
Old Jun 11, 2012 | 05:47 AM
  #795
Kracka's Avatar
Correct, which is why I won't be getting them No cams and no lightweight flywheel this time around.
