Borgwarner Twin Scroll 7670 With Dyno Graph
I think they can actually sell down to E60 in some parts of the country while still having it marked as E85. I remember seeing a map saying such anyway a long time ago and Utah happened to be one of those areas due to our high elevation and low winter temps.
Back to the topic at hand though, EFR7670. I'd really like to see some success stories out of these things. They looked so damn promising, but man they are like 0 for 10. This isn't the only EFR thread that showed promising results and then a blown turbo shortly after.
The complicated part I see is that if you fill the car, and then use the GM sensor or the glass jar, and find at that point that you've only got E50 or some other junk, then you've got 14 gallons of that junk in your tank now. How do you check and then fill, and make the process practical?
Are you running Haltech pro or sport? Currently only the pro supports 4D tuning. The next firmware update for the sport will support the GM sensor for proper flex fuel capability allthough its about 6 months away.
I have the TTP Eth content gauge. So far its still E85 here in GA (A little shocked by that to be honest). I played russian roulette for 2 years before that.
The GM flex fuel sensor is the actual sensor that gives the signal.
In other words, stand alone ecu's that can use that ethanol input to compensate mixture based on ethanol content don't need the Zeitronic display, just the GM flex fuel ethanol sensor.
For those that don't need another gauge, but just want the functionality, the GM sensor is 'all' you need
