Borgwarner Twin Scroll 7670 With Dyno Graph
Old Dec 6, 2011 | 06:05 PM
  #616
Geoff Raicer's Avatar
Originally Posted by JARVEVO8
I was at the PRI this weekend and saw a company that cleans oil coolers and any type of coolers like radiators, intercooler, etc... they use an ultra sonic cleansing high pressure machines in a 4 way process with 4 different machines. Im sending mine this week...If you need the info let me know...I met Geoff at the show too, it was nice meeting him, very cool guy.
nice to meet you too jose - would you mind PMing me the company who ultra-sonic cleans heat exchangers? thank you
Originally Posted by 94AWDcoupe
aluminum stuck to turbine wheel is quite common and and an easy fix. whoever is trying to tell you its shot is trying to steal the turbo from you. have it sent to me I will give you 500 for it. and I am being serious.
what are you talking about?? this is no simple fix, chunks of piston went thru the turbine wheel. the turbo sustained FOD (foreign object damage) and should not be run. if you pay for known damaged turbos that look like this attachement (leetevos turbo) you are asking for trouble
Attached Thumbnails Borgwarner Twin Scroll 7670 With Dyno Graph-bendenkers-fod-7670.jpg
Old Dec 6, 2011 | 08:24 PM
  #617
94AWDcoupe's Avatar
man I have run 35r turbos with three times that amount of tip damage. sure curbside appeal is lost, sure they average joe freaks out when he sees it. NO loss of performance what soever. ever heard of of a clipped turbine wheel?? I would run that turbo like white on rice for 500 bucks. but thanks for defending yourself.
Old Dec 6, 2011 | 08:42 PM
  #618
RSMike's Avatar
is the discolouration on the shaft from lack of oil or something else?
the binding process?
Old Dec 7, 2011 | 12:46 PM
  #619
batty200's Avatar
I would also use that turbo for $500. Damage is barely anything.
Old Dec 7, 2011 | 04:09 PM
  #620
JARVEVO8's Avatar
PM'ed
Old Dec 7, 2011 | 06:08 PM
  #621
David Buschur's Avatar
I'm with you guys, I'd run it and have also run much worse with no signs of loss in performance.
Old Dec 7, 2011 | 06:16 PM
  #622
this is a time attack car, it spends 20 minute sessions with that turbo spinning well over 130k rpm peaks... not a drag car making 9 sec passes. not wise for it to be operating at those speeds, out of balance
Old Dec 7, 2011 | 06:49 PM
  #623
batty200's Avatar
none of us said he should use it but that WE would use it. If you are condemning it to death using it until it is really dead is a no brainer to me. Turbo failures dont usually cause engine damage and with a restrictor this would smoke a lot before it used up all the oil in the car.
Old Dec 7, 2011 | 06:50 PM
  #624
batty200's Avatar
Also the balance wouldnt be terrible if you got all the melted aluminum off the turbine wheel. A torch seems like a decent method. I am not sure if that is Jerry's method.
Old Dec 7, 2011 | 07:16 PM
  #625
CBRD's Avatar
Yea- imbalance for sure.... Taking it apart and not have the comp and nut in the exact position as before= imbalance.
Flirting with disaster
Old Dec 8, 2011 | 06:28 AM
  #626
Oh, well that changes everything It's tough for me to even get to work over the last 20+ years of doing this to be honest. I have to start my car, go WOT for 9 seconds, then shut it down, stop and do it again and again until I get to where I am going. I know it sounds fun but believe me fellas, it's tough being able to do nothing but drag race everyday of my life. My poor Explorer I just bought doesn't know what to think, start it, punch it to back out of the garage, shut it off, start it punch it to get to the end of the drive way, shut it off, on and on and over and over again........
Old Dec 8, 2011 | 07:00 AM
  #627
blackenedwings's Avatar
I wouldn't run that turbo for $500 or $5. There is no point in doing something cheaply when you have a fully built car. Cutting corners like that almost invariably costs more in the long run. You wouldn't run a time attack car with a used oil cooler from a car with a catastrophic failure even if you had gotten it cheap and cleaned it. The cost isn't worth the risk. I feel the same way about a turbo with foreign object damage.
Old Dec 8, 2011 | 10:17 AM
  #628
CBRD's Avatar
sigh-
so damaged tips- imbalance-
aluminum on the blades- try to remove it- still imbalanced-
torched bearing area-
all good things
this = awesome!
Old Dec 8, 2011 | 11:45 AM
  #629
RSMike's Avatar
file off the damaged areas.
remove the melted on alloy.
send the CHRA to MAPerformance to spin up on their VSR machine... Balanced.
Cheap turbo.
Old Dec 8, 2011 | 02:30 PM
  #630
evoxsi's Avatar
welll i guess we can all just buy those chinese ebay turbos now that balanced turbos offer no performance gains.
