big numbers on a stock 9 turbo on e85
Yes I need to lose some weight. 2 people in the car during the tuning. Not sure if Tom has adjusted the vehicle weight based on weight reduction mods.
It's looking like we are going to hold off until ~January 2012 to get her back up and running. Notional upgrades include:
FP DBB Black
ToxicFab exhaust manifold
ToxicFab O2 dump
Shep ultimate ratio tranny
Exedy triple
BR double pumper
FIC 2150 injectors
At the very least we will get the tranny, clutch, double pumper and injectors. The Black, mani and dump will be purchased no later then summer 2012. My wife and I are more than ready to take our Evo to the next level and see what we can achieve on the stock block. Can't wait to have Tom work his magic!
FP DBB Black
ToxicFab O2 dump
Exedy triple
BR double pumper
FIC 2150 injectors
remove 8% from the actual number and you have mustang pretty much. why dont you run a log through it and compare it on your vehicle? if you have a programmer and laptop and evoscan you can do it. also mitsulogger will work.
2 people in the car him and his wife. wife was working the laptop he was driving ( i think) .. some runs there was a 3rd also.
not going to happen .. i will keep torque around 380-400 and make the hp very high. have dozens upon dozens of cars over 500 on stock block with low torque running fine. the torque is what causes the damage.. so just keep the torque in check and the engine will last quite a bit. now right now he has lots of torque cause thats what he asked for.. but if we tuned the fp black setup like that it would definitely not last long i agree with you.
The engine may not last...I want to maintain ~425tq and go up to ~550hp. She's a stallion Tom, remember? Lol
Two more mods will be accomplished in January:
BR ported intake manifold
BR 65mm throttle body
I did a boost leak test prior to Tom starting the tuning effort and found one leak--throttle body. I believe it is the shaft seals but am not 100% sure. So, the tuning was done with a fairly significant boost leak.
ya i remember you telling me the tb had a leak in it. the question is when you go say 20psi and stop pressurizing, how long does it take to get to 0? how significant is the leak? because if its bad without any pressure hardly its 10x worse under real boosting.
either way i dont think it effected overall power to much because we just made up for it with more WGDC.. at the same time that can make the air hotter by overspinning the turbo to get the same boost as if there were no leaks it would not be spinning as hard for the same boost.. so its hard to say. especially with e85.
seriously? so it only held 5psi during a test and it held it for how long? a split second? in that case you're lucky the turbo didnt blow.. i thought it was fishy i had to run around 80% wgdc even with the 25psi WGA MAX preloaded. once its fixed dont boost the car it will be way to high of boost.
so theres more in the car then.. because we were spinning the turbo excessively to build a certain boost level to make up for a huge air leak.
o well. still made sick power
similar to if you had a water hose and it had a huge leak in it.. you would turn the water pressure up higher to make up for that leak. it just overworks everything and the setup becomes less efficient.
next time we will make sure everythings 100%.
Is pushing this much boost putting the turbo out of its efficiency range? I am really hoping that I get shot down with this as I have my turbo selections narrowed down to two. Basically I am torn between making 450whp on the stock IX turbo or 500whp on the EF3 turbo.
tscompusa2
Jul 17, 2012 10:26 PM
tscompusa2
Feb 27, 2012 09:30 PM
