Official "Pure" 91 octane evo thread
Old Aug 12, 2013 | 11:59 PM
  #136
01sporty's Avatar
hx40 evo pump
This car is just insane in the build quality and the attention to detail. I was thoroughly impressed by the responsiveness of this turbo and the whole car. I don't understand why more people don't utilize these cheaper turbo options
this is 100% 91 octane and at 4800 ft above sea level in utah(slc) I was being conservative on his tune because he daily drives it and also track races too.
The car mod list to the best of my knowledge
2.3 stroker motor eagle rods. wiseco pistons
stock head
supertech springs
gsc s2 cams
880cc injectors
walbro 255 modded
jacks transmission trans and t case
EBB Fab top mount twinscroll kit
EBB Fab 3' aluminum intercooler piping
Holset hx-40 hybrid with borg warner compressor wheel
holset 12cm (.89 A/R housing t3)
twin mvs wastegates
ets garret core
stock intake manifold
stock tb
sparktech cop kit
stock 7 heat range plugs
this car has been lightend and had huge widebody kit and also on some knarly rpf-01 the weight is scaled weight with two people in the car and the pull was in third gear at 31psi tapering to 27 by redline
tires are 265/45/17
Attached Thumbnails Official "Pure" 91 octane evo thread-broderickevo-sae6.jpg   Official "Pure" 91 octane evo thread-bjevo.jpg
Old Aug 13, 2013 | 12:04 AM
  #137
Lang55esan's Avatar
Don't wait for everyone to come in here and repost all their dyno graphs.
Old Aug 18, 2013 | 11:12 PM
  #138
Sideck's Avatar
HTA86 @20 psi / 432 WHPS
100% 91 Oct...
Old Aug 19, 2013 | 04:32 AM
  #139
HsamehH's Avatar
can you post all your mods ?
Old Aug 19, 2013 | 12:47 PM
  #140
Sideck's Avatar
sure,
Buschur 2.0 (10:1 compression)
HTA86 .82AR / 2.5" Vband
SDK Racing Head
* MAP In/Ex Valves Stock Size
* 3 angle valve job
SDK 4" CAI
GSC S3 Cams
GSC Valve Springs/Retainer/Seat Kit
ARP L19 Head Studs
MAP T3 Exhaust Manifold
Kiggly Racing - HLA Pressure Regulator
ARP L19 Headstud Kit
SDK 3" Downpipe
SDK 3" Full Exhaust
FB 70mm Throttle Body
JMFAB Drag Intake Manifold
Speed Density / Stock ECU
Omnibar 4 Bar Map Sensor
44mm Tial WGA
50mm Tial Bov
4.0" ETS Intercooler
Buschur Dual Fuel Pump
AMS Fuel Rail
SDK -6an Fuel Feed Line Kit (from the tank)
Stock Return Fuel Line
SDK Return Line Kit (Fuel Lab FPR)
PTE 1200cc Injectors
Spoolinup COP Kit
AEM Adjustable Cam Gears
Tilton Twindisk Clutch
dejon tool dual MBC
2 map switch
Race Gas Tune:
Q16 @38psi / 734 WHPS (we need bigger injectors for more boost)
Old Aug 20, 2013 | 03:34 AM
  #141
HsamehH's Avatar
awesome results,it seems the HTA3586 works pretty well over 20+ psi
Old Aug 26, 2013 | 03:43 PM
  #142
blackoutVIII's Avatar
Originally Posted by blackoutVIII
With my mods, I was tuned on a mustang dyno 264whp and 282tq on 91 octane. When I was on 93 Octane my numbers were 334whp and 352tq (tuned by Mellon). Going from 93 to 91 octane I lost about 20% power. Is this normal?
91Octane fuel , I am in Az.
93 Octane, I was in Texas.
If this makes a difference.
Any takers on this? My VD also calculated 260ish WHP and 260ish torque.
I am waiting to recieve my CAMS (Backorder Sep time frame) to instal and re-tune.
Old Aug 26, 2013 | 05:21 PM
  #143
Sideck's Avatar
is 100% normal, you can run more boost on 93...
Old Oct 12, 2013 | 03:39 PM
  #144
weaselandahalf's Avatar
Mods:
UICP/LICP
Intake
TBE including 02 housing
Evo 9 Turbo
Walbro 255
ECU Boost Control
Tuned by me @ ~25psi (this was one of the earlier runs that I did so the boost is not as consistent in the midrange, but it is better now)
I think 342 is a little high because there is a little upward then downward slant at the end of my road that makes VD show less power (around 6,200), and then a little more at the end. I doubt I will keep the car at 25psi for long, though.
Old Oct 12, 2013 | 04:44 PM
  #145
kaj's Avatar
kaj
Originally Posted by weaselandahalf
Mods:
UICP/LICP
Intake
Evo 9 Turbo
Walbro 255
ECU Boost Control
that is very high. with the same mods as you, on a IX, with 264 cams, i only managed 334whp.
Old Oct 12, 2013 | 07:46 PM
  #146
Boosted Tuning's Avatar
Mods:
UICP/LICP
Intake
Evo 9 Turbo
Walbro 255
ECU Boost Control
Do multiple pulls and look for consistent results, not one-time flukes.
Old Oct 12, 2013 | 09:01 PM
  #147
I read the sticky! Lol...I get consistent results, I have probably done over 100 pulls on this same road lol. While I was pretty much done tuning for 25psi, the VD always showed within 5 or so hp of 340, but does having a downhill at the end of the road I test on make VD think the car has more power than it actually does?
Old Oct 12, 2013 | 10:49 PM
  #148
kaj's Avatar
kaj
yes. hp is figured by using rpm and time. rpm rising in less time = more power.
Old Oct 13, 2013 | 08:23 AM
  #149
Yeah, thats what I figured. It makes sense on the graph too because the power dips slightly when i would be on the uphill and then rises slightly on the downhill. It's more noticeable with less smoothing too. Thanks!
Old Oct 13, 2013 | 12:43 PM
  #150
kaj's Avatar
kaj
just for fun, do a run downhill. the graph is awesome. LOL
