MAP EF2.5 Evo 8 E85 Results & Data
Its only tephra v7 that has an option for 100% WGDC below a definable load.
I'm not going to waste my time taking parts off of my car to put onto another and switching them back onto my car to prove anything to you. I'm not being paid for my time and effort.
You can say I'm wrong but I know what I experienced and so does the owner and another local. I have no reason to BS my friends or anyone on this forum.
I just retuned my car for a MBC and switched the GS to the other car within the past 2 weeks. The only reason the switch was done in the first place was so I could show him he needed the GS to keep the car safe and make the power he wanted and have decided to leave the GS in place.
You experienced something different than me which is fine. This is why having an open forum is a good thing.
I know you are a big advocate of "hybrid" boost control and probably one of a few who are but I am not. We have different tuning styles which maybe is why we have different results. I have been around for a long time and have seen my fair share of tuning and results.
I don't know what else to say. if you want to continue thinking what you're thinking in the regards of the way they perform that is perfectly fine. im only trying to help. <-- i realize you can say the same for me.
I got really angry/upset though when i read what you posted that i highlighted in bold. I felt that was a very rude comment.
Its ok though. i made it clear that im very confident in what i said, and if need be have a ton of cars that can back my claims up. Im not going to have my customers flood this thread though just to prove a point.
At the end of the day you have experienced a different result on two cars, that i have not on probably 80 atleast off the top of my head on hybrid boost alone.
I've converted cars over to mbc that were on 3 ports alone that had serious boost creep, after adding the mbc the creep went away. why? because there was not enough boost being built soon enough downlow to avoid the creep. that alone should be enough proof to show that the mbc can do things the 3 port is not capable of on our ecu.
FYI the Forge UNOS according to boosted tuning's test is the best spooling, and holds boost the best out of all the ones he tested if you decide to go that route.
spool over the titek? maybe. More power compared to the titek+stock downpipe? yes definitely. I think map's 02 eliminator downpipes are the best setups out there at the moment, but the dump is going to be better, especially for spool. The stock turbine housings even with TD06/TD06H turbines machined in them are actually quite restrictive and the more airflow you try to stuff through them from larger stock framed turbos the more of a difference in spool and power an 02 dump is going to make as it doesn't disrupt the helix and releases back pressure off the turbine wheel. Ever wonder why 02 dump set-ups cause boost creep? ;-) The stock internal wastegate passageways are not really large enough to control turbine speed when it's free flowing(and the turbine aero has a huge part to play in this variable as well, but we won't go into that). You just don't ever creep on a recirculating setup because the added back pressure on the turbine wheel actually is like a bandaid and allows the internal wastegate to keep up. FYI It's an even bigger problem on the anemic 28MM flapper on the 7cm dsm housings.
in alot of cases yes. The FP black guys are reporting 200-400 RPM better spool just by going 02 dump. Look it up.
In my honest opinion I think the way forward for your goals is 4" intake+SD, 02 dump, and a hybrid setup, and if you happen to make more power along the way with the better spool and response then I don't think you will complain. my thoughts.
And thanks for the lesson, will file it away in my 'boost knowledge' mental library.
