Evo IX 2.0 Mamba Turbo GTX3584R + water/meth. injection
Clearly it'd be kg - it's hardly going to inflate the figure if it was 1600lb, so not being dodgy and I am pretty sure there are very few places where people still use antiquated units like "lb" so unless it's an American posting, I'd assume metric where not stipulated.
[QUOTE=KameloT;11517508]2.0
ETS T4 ts. manifold
Mamba Turbo GTX3584R a/r 0.70 with T4 ts. a/r 1.06 housing
Kelford TX280 cams
AEM v.2 w/meth. kit
Speed Density on stock ECU.
DynoJet on Virtual dyno on 3rd gear:
Comparison with Garret GTX3582 with same boost (about 2.7 bar) :
With the same spool and response , Mamba give minimum +50whp from Garret
Did you make any other changes to the car than the turbo? Like other ic or tb or so?
And how does the turbo hold up? How many kilometers do you have on it now?
Ron
ETS T4 ts. manifold
Kelford TX280 cams
AEM v.2 w/meth. kit
Ron
ETS T4 ts. manifold
Kelford TX280 cams
AEM v.2 w/meth. kit
With the same spool and response , Mamba give minimum +50whp from Garrett
ETS T4 ts. manifold
Kelford TX280 cams
AEM v.2 w/meth. kit
Freddy302
396
Jan 25, 2010 10:34 AM
DynoFlash
25
Aug 27, 2007 12:00 PM
boomn29
28
Feb 14, 2007 10:29 AM
