Data on internal vs external WG
Old Mar 23, 2017 | 01:26 PM
  #91
03whitegsr's Avatar
No aero drag when the wheel is under vacuum. Have to imagine the bearing system is built to handle it though.
Old Mar 23, 2017 | 05:01 PM
  #92
JohnBradley's Avatar
They were also subject to being oversped in that configuration. I would love to revisit it with a modern ECU and a DBW throttle. I think if you coupled all of that with a turbo speed sensor that it would be easy to maintain a safe max shaft speed in vacuum.
Old Mar 24, 2017 | 12:55 AM
  #93
kikiturbo's Avatar
it would require some intersting control strategies as it would not be following the main throttle directly.. Interesting stuff.
Old Mar 27, 2017 | 11:34 PM
  #94
03whitegsr's Avatar
Yeah, modern control hardware could probably make it happen pretty easily.
I was more talking about thrust loads when putting the compressor in vacuum though. Ball bearing turbos use angular contact bearings and I don't THINK they would be too happy with thrust loads in the opposite direction then what they normally see. I could see them smoking like crazy too.
There are some pretty cool turbo F1 and GrpB documentaries though on YouTube that actually give a great look at the era. I'd say what is being done today on the street car side is actually pretty inline with what was top tier technology of that era. Lots of the parts that you see in those documentaries could damn well be mistaken for stuff being used today.
Old Mar 28, 2017 | 12:48 AM
  #95
RightSaid fred's Avatar
That would be no different from running a carburettor in front of the turbo. When you size it right you don't need a wastegate at all.
As was done regularly 35 to 40 years ago with v8s.
Old Mar 28, 2017 | 09:06 AM
  #96
LetsGetThisDone's Avatar
Not exactly, there was a pre and post turbo TB on those old F1 cars.
Old Mar 28, 2017 | 12:30 PM
  #97
As far as vacuum goes, with a carb, the inlet is always in vacuum.
asimpson719
Lancer Aftermarket Forced Induction Tech
Mar 23, 2009 12:27 PM
lancerdave86
Mar 18, 2009 08:07 AM
boostdtalon
11
Sep 18, 2008 10:59 PM
pedro342
May 13, 2005 08:45 AM
Pimpson
Lancer Engine Tech
Sep 15, 2002 01:27 PM
