Post exact weights of weight reduction you have done!
Old Jan 13, 2012 | 05:45 PM
  #661
badev0's Avatar
I just got mine down to 14lbs as well. How the hell did you take off 8?
Old Jan 13, 2012 | 05:50 PM
  #662
EvoDan2004's Avatar
Haha maybe ill keep this one a secret. Haha.
Also if you want to go nuts you can remove all a/c and abs wiring from the dash harness.
Old Jan 13, 2012 | 05:53 PM
  #663
badev0's Avatar
Lol. Post pics now!
Old Jan 13, 2012 | 06:07 PM
  #664
IzzyRS's Avatar
Originally Posted by StreetThisEvo
Where did you get that scale from?
your local drug dealer might be able to cut you a deal on it
Old Jan 14, 2012 | 12:23 AM
  #665
EvoDan2004's Avatar
i really need to be stopped here. guys. look at this damn dash harness. its 3:15am and i been sitting in my car staring at it. there is so many plugs not in use that mitsu tied off. also if you removed your ABS, SRS ''air bag's'', A/C etc all that CAN GOOOOOOOOO. i bet there is 3+lbs in this harness. right now in this stage of work i have saved 8lbs in the bar, 3lbs in a/c removal from the heater box, 7.3lbs pass air bag, 2lbs ''abs computer'' thats a total of 20.3lbs. i might try for a goal of 25lbs total. dude. thats crazy.
ever try sam smith oatmeal stout?????????? this **** is great.
Old Jan 14, 2012 | 01:03 AM
  #666
EvoDan2004's Avatar
ok scratch that. do not do it. i started to do it and noticed each one of those ''not in use'' plugs are in use. they seem to be jumpers or something. strange. o well. im happy with 20.3 now. and its bed time
Old Jan 14, 2012 | 02:47 AM
  #667
tscompusa's Avatar
you guys are nuts.. im to lazy to remove weight from my car.. i guess you could say im nuts also for having a full weight evo
Old Jan 14, 2012 | 04:50 AM
  #668
StreetThisEvo's Avatar
Pics now!!!!
I want to see your bar damnet.
Old Jan 14, 2012 | 06:06 AM
  #669
badev0's Avatar
Pics now!!!!
If it makes you feel any better, here's my bar
Old Jan 14, 2012 | 08:05 AM
  #670
Well here is mine. I think I am just gonna call it quits and not waste anymore time on it. I have to many other things to do and 1.x lbs isn't that big of a deal considering I the 6.x lbs already removed. I should have no problem hitting my 259x lb street weight goal for 2012!! I can't believe I didn't do this earlier. I left all the key mounting points to make sure the dash is nice and stiff still. Anyway here ya go:
Today I plan to work on my wiring harness a little more. You can follow my 2012 build thread here:
https://www.evolutionm.net/forums/ev...unting-8s.html
Old Jan 14, 2012 | 09:39 AM
  #671
B.J.@ToxicFab's Avatar
Badev0, it definitely looks like you removed a bit more stuff off your car than Chris (streethisevo) did. Badev0, what is your bar down to, weight wise now?
Nvm, just saw you posted 14 lbs on the previous page...
Dan, what is your bar down to now??
Old Jan 14, 2012 | 09:50 AM
  #672
EvoDan2004's Avatar
You guys removed a lot more then I did. Yet I removed parts you guys didn't. I'm sure you csn get yours lighter then mine. I kept all mounting points for the stuff I need. You removed all that stuff.
Bj my bar weighs 12.8 lbs. But I have something I need to do to the bar before I post pics.
Old Jan 14, 2012 | 10:03 AM
  #673
Once I go through the wiring under the dash that harness will be cut in half. I plan to loom it and zip tie it to the bar. So I said F it and just removed those tabs.
Old Jan 14, 2012 | 10:06 AM
  #674
EvoDan2004's Avatar
What do you plan to remove from the harness? Be careful because them plugs not in use actually are
Old Jan 14, 2012 | 02:45 PM
  #675
badev0's Avatar
Weighed mine again and it was 13.6lbs. Good enough for me. Also the a/c vaporator and srs ecu = 5lbs.
