Post exact weights of weight reduction you have done!
Old Jan 12, 2012 | 11:58 AM
  #631
badev0's Avatar
Originally Posted by evodan2004
i removed the a/c all the way up to the fire wall. after that i do not know what is left. is there a kit on your site i need i can buy?
i removed those brackets. it now weigh's 15.2lbs. my stock bar weighed 20.8lbs. 5.6lbs off the bar. and i still have some extra idea's. i need 2.4 more lbs.
Post some updated pictures of your bar, i'm curious as to what you've removed so far
Old Jan 12, 2012 | 11:59 AM
  #632
EvoDan2004's Avatar
its not done yet. i have a few other idea's. ill post up some pics of what i did though up to this point. give me a few min ill go take them now.
um. ignore the yellow floor
Old Jan 12, 2012 | 12:03 PM
  #633
badev0's Avatar
lol. sounds good, thanks!
Old Jan 12, 2012 | 12:16 PM
  #634
B.J.@ToxicFab's Avatar
I removed those brackets. it now weigh's 15.2lbs. my stock bar weighed 20.8lbs. 5.6lbs off the bar. and i still have some extra idea's. i need 2.4 more lbs.
Nice! Pics!
  #635
EvoDan2004's Avatar
ok here are some pics. look at my stock pics for a before and after.
also note the corners i trimmed up. there is other stuff done that the pics do not show but just use your imagination.
at this point i will not be replacing the main bar with something else. i do not feel it will net anything. and im not spending 100+ dollars for 1lb. or risk becoming heavier. to honestly see if its worth it someone needs to cut EVERYTHING off the bar and weigh just the bar. then we can see what material we can use and if it will be lighter.
i still have more to do. so this is about half way.
Old Jan 12, 2012 | 12:27 PM
  #636
badev0's Avatar
Looking good! I'm going to remove mine this weekend and stock up on some cutting wheels
Old Jan 12, 2012 | 02:30 PM
  #637
StreetThisEvo's Avatar
Ditto!
I have a good idea for mine. Thanks David
I'll keep you guys updated if it works out well.
Old Jan 12, 2012 | 02:33 PM
  #638
David Buschur's Avatar
Man you guys are hard core! haha
Old Jan 12, 2012 | 02:34 PM
  #639
EvoDan2004's Avatar
Originally Posted by StreetThisEvo
Ditto!
it depends how crazy you want to get. you can remove all the tabs and some other stuff but then your going to have issues holding up the dash harness.
also when your dash is out look where the glove box would be. there is that bracket there that bolts to the bar. IMO i would leave that as well.
i burned up 3 wheels. and im not done yet. so stock up for sure. next step is stage 2 on the bar. im going to post pics when its complete. good luck guys. hit me up for any help or tips
p.s. i ordered another steering column. my original one broke and im using it to see how much i can get off that without hurting its structure. we shall see
Old Jan 12, 2012 | 02:41 PM
  #640
Ha and your not....LOL
Old Jan 12, 2012 | 02:44 PM
  #641
badev0's Avatar
Every bit adds up
Old Jan 12, 2012 | 03:52 PM
  #642
Well you guys suck....I even being sick right now just went out and pulled my dash bar out haha. I figured it is warm in the house and I'll just mod it in the basement. I weighed mine and it came in at 20.4 lbs. My goal is 13 lbs. Should be pretty easy.
Keep the pics coming Dan. It helps a lot.
Old Jan 12, 2012 | 04:10 PM
  #643
EvoDan2004's Avatar
No problem. Post you your process as you go
Old Jan 12, 2012 | 04:21 PM
  #644
griceiv's Avatar
you can open the heater box and remove the evaporator. you don't need any special parts.
Old Jan 12, 2012 | 04:37 PM
  #645
badev0's Avatar
Also, be sure to keep your keys as light as possible.
Before:
After:
