Post exact weights of weight reduction you have done!
Old Aug 28, 2012 | 09:05 AM
  #1411
Gary@MellonRacing's Avatar
There is a mod i did for a Car on the Glove compartment , ill try to get a pic and upload it
Old Aug 28, 2012 | 02:04 PM
  #1412
Kidloco51's Avatar
I just ordered some Fiberglass headlight replacements today, they weigh 1 lb 5 oz each. I need to weigh my stock IX HID headlights. Anyone know the weight?
I also did a lexan front windshield this last month. My guess is it saved about 12-15lbs
Pics:
Old Aug 29, 2012 | 04:59 AM
  #1413
B.J.@ToxicFab's Avatar
^^^I like your car more & more everytime you post pics of it...I would love to take it around a track once!! Looking good man!
Old Aug 29, 2012 | 10:02 AM
  #1414
antilag_200's Avatar
Here is a few things that I have recently done,
a carbon plate to delete the airbag and retain the stock steering wheel
a carbon plate to cover the holes for the AC that goes through the firewall
Replacement of upper and lower radiator hoses to -16 AN prolite hoses, which saved some ounces over the stock silicone and tbolts
Power steering line HP side was changed to prolite hose, and the LP side was bent up into -6 AN aluminum line
Old Aug 29, 2012 | 10:16 AM
  #1415
DaveK's Avatar
Keep a close eye on the powersteering lines. I've seen another Evo that did that have problem after problem in a road race type application with the off the shelf type AN lines. The eventually went to industrial strength hydraulic lines which solved the problem.
Dave
Old Aug 29, 2012 | 10:21 AM
  #1416
Dave
agreed, my high pressure side one needs to be changed to teflon lined hose with compression ferrules. This iteration was for proof of concept, as I ran the line under the motor mount ( High pressure side)
Old Aug 29, 2012 | 10:44 AM
  #1417
Looking good antilag! I always enjoy seeing little weight reduction things you do, they all add up! What does your car weigh now?
Old Aug 29, 2012 | 10:58 AM
  #1418
Thank you B.J, I am currently building a resevoir tank for the power steering ( It won't be anything as cool as the stuff Toxic fab produces), so I will post that up when I am finished.
the last time I weight it on a scale it was 3120 with me (162) in it ( 18s, baby seat, half tank of gas, and an exedy flywheel)- so still pretty heavy.
Old Aug 29, 2012 | 11:07 AM
  #1419
Collin just re-did all of his PS lines & he is about to build a PS res/tank as well. Not sure if it will be a production item or not, as a lot of the stuff he is doing for his build are one off custom pieces. Sounds like our cars are similar in weight. My car is an MR & once I do my 5 spd swap & throw in my Non-ACD T-case , I am guessing my car will be slightly under 3000lbs without me. I still have AC, full stereo, full interior, power everything, etc.
Old Aug 30, 2012 | 01:56 PM
  #1420
PsychDr. HN$'s Avatar
So many ideas in this thread. My goal is to hit 2800...with a full cage.
Old Aug 30, 2012 | 04:09 PM
  #1421
EvoDan2004's Avatar
my car is 2780 with a cage, sunroof, HIDS, brembo brakes, full interior, upgraded stereo, power windows/door locks, and so on.
this winter i have a list and goal to make the car look exactly how it does, still have all of the above and will weigh 2680. thats a bad *** street car. i cant wait to get started
Old Aug 30, 2012 | 04:14 PM
  #1422
Kidloco51's Avatar
2780. My mind is blown. I can only dream of my car weighing being that light.
Old Aug 30, 2012 | 04:31 PM
  #1423
AreSTG's Avatar
Do you have a build thread, where you cover the weight mods you've done? I have read the countless pages here, but seeing exactly what you did would be VERY helpful to me.
I want to achieve similar results, keeping interior looking normal and such. Though, at this point powersteering, a/c, and ABS are all still going to be staying.
Old Aug 30, 2012 | 04:39 PM
  #1424
EvoDan2004's Avatar
no i do not. most of it is in this thread and what is not in this thread i keep to my self.
Old Aug 30, 2012 | 04:48 PM
  #1425
artinist's Avatar
are those fender mounting allen bolts and washers from a kit or did you put it together yourself.
