Post exact weights of weight reduction you have done!
Old Feb 27, 2012 | 11:44 PM
  #1006
EvoDan2004's Avatar
rear wheel bearing ''no studs'' 6.7lbs.
do they make Titanium extended studs? ARP's studs are heavy.
Old Feb 29, 2012 | 07:55 AM
  #1007
EGbeater's Avatar
They're not actually all that bad, although I understand some of you guys are trying to drop every last possible ounce (but Ti wheel studs is a really poor way to lose weight, in terms of dollars to weight savings).
OEM wheel studs:
ARP 100-7017 extended studs:
What ARE superheavy are wheel spacers/adapter with any significant thickness to them, say 15 mm or more.
These are 20mm thick, 5 x 114.3, 67.1mm center bore wheel spacers with built-in studs, with the five extra 17mm hex-drive, generic steel lugnuts necessary to bolt them on (the lugnuts are barely over a quarter pound):
And these are 30mm thick, 5 x 114.3, 67.1mm centerbore wheel spacers made of 6061 aluminum... who knew alumimum could be so heavy.
Of course, I could have paid the machine shop more money to machine out the areas between the studs to save some weight, and maybe I still will, down the road, but at the time I was being cheap:
Old Mar 1, 2012 | 04:49 PM
  #1008
03whitegsr's Avatar
rear wheel bearings ''with studs'' ill remove them tomorrow. or later today haha. 7.5lbs
rear E-Brake assembly. this includes all the hardwere, rear E-Brake shoes, backing plate's, and E-Brake line's. 9.3lbs.
rear spindles. you can kiss my ***. im not taking them out until i need to. haha. dont even ask.
FWIW, I listed all the rear parts a while ago. Looks like a small 0.7 lb difference observed on the E-brake stuff, but 0.4 of it could simply be scale resolution. Hub looks to be within scale resolution. Good to see similarities in weights for a sanity check.
Originally Posted by 03whitegsr
Everything here is from the rear, one side only. As always, +/-0.2 lbs
Code:
E-Brake Assembly    	5.0	Cable, Back plate, Shoes, Hardware (one side)
Hub Carrier             9.4	Carrier and wheel speed sensor
Upper Control Arm    	4.4	Ball joint nut, no other hardware
Toe Control Arm        	2.4	Ball joint nut, no other hardware
Hub Bearing Assembly	7.4
Axle                   13.4	axle nut included
Trailing Arm       	4.0	Ball joint nut, no other hardware
Lower Control Arm  	3.6	No hardware
Old Mar 1, 2012 | 05:38 PM
  #1009
EvoDan2004's Avatar
we need to make a new weight thread with someone that is willing to update the orignal post every once in a while.
Old Mar 1, 2012 | 06:11 PM
  #1010
4g63evoeight's Avatar
run the list Dan! then i'll look through it, not reading 68 pages lol.. but i've deffinatly been watching the last few pages LOL.
Old Mar 1, 2012 | 08:39 PM
  #1011
EvoDan2004's Avatar
i would but where the hell do i start? haha. i guess i could brake it down and just let people PM me with what they have like i did on highboost forum
Old Mar 1, 2012 | 08:41 PM
  #1012
i would but where the hell do i start? haha. i guess i could brake it down and just let people PM me with what they have.
yea and sift through the 68 pages haha
Old Mar 1, 2012 | 08:44 PM
  #1013
EvoDan2004's Avatar
where should i start it. is this the right section or should i put it some where else. i mean it kinda covers interior, exterior, drive train, electrical, engine, suspension and so on
Old Mar 1, 2012 | 10:30 PM
  #1014
03whitegsr's Avatar
I've got a spreadsheet with MOST (if not all) of the weights posted in this thread. I've just updated it as the thread has progressed.
I don't really feel like going through it and verifying again though.
Old Mar 1, 2012 | 10:32 PM
  #1015
EvoDan2004's Avatar
do not verify anything. just make a new thread and keep it up to date. everyone scale is different. so if its a little off from each person thats ok. if we come up with something greater then what it looks to be then we can discus.
Old Mar 1, 2012 | 11:01 PM
  #1016
03whitegsr's Avatar
Ha, looking through what I have, I've got multiple entries all over (different sources), lots of custom parts that wouldn't apply to anybody else and its spread across 5-6 different spreadsheets. It will take a while to go through.
Old Mar 2, 2012 | 05:10 AM
  #1017
B.J.@ToxicFab's Avatar
I'm down for a new Weight Reduction thread...I have an accurate scale now & I've been weighing a bunch of stuff lately.
Old Mar 3, 2012 | 01:37 PM
  #1018
EvoDan2004's Avatar
sweet. do you know where the ''new thread'' button is? click that. haha.
i will do it if i am forced too but i really do not want to haha
Old Mar 3, 2012 | 02:07 PM
  #1019
03whitegsr's Avatar
Yeah, I'm not going to update a thread for those that can't search. It would be nice, but I don't care that much.
Just one more weight...
EVO IX turbo
No wastegate actuator and all studs removed - 19.2 pounds
Old Mar 3, 2012 | 02:11 PM
  #1020
mullen's Avatar
EVO IX turbo
I agree, this thread is full of material...maybe update the first few pages though
