Post exact weights of weight reduction you have done!
Old Apr 8, 2012 | 02:06 PM
  #1141
EvoDan2004's Avatar
Originally Posted by badev0
that's exactly what mine should weigh based on calculations lol. No cage though with sunroof. Getting mine weighed next Saturday when the track opens.
I might take my cage out if the track gives me more Bs this year. I'll just do track rentals or something. Then I should be around 2750 range. I still plan to do the sunroof delete but i have no time to get it completed right now
Old Apr 8, 2012 | 03:28 PM
  #1142
Evo8RA's Avatar
My '03 Evo8 is now down to 2250 lbs without cage- confirmed weight on COBB Tuning's scales a couple of weeks ago. Unfortunately, I have to carry 350lbs of ballast this year to hit minimum weight for FP autocross (2600).
Old Apr 8, 2012 | 05:16 PM
  #1143
David Buschur's Avatar
Post some detailed pics of the car, I'd love to see it, that's LIGHT!!!
Old Apr 8, 2012 | 05:23 PM
  #1144
ExtremeDSM's Avatar
2250!!! Good god, did you pull the motor and trans out? You must be Flinstonin it.
Old Apr 8, 2012 | 08:37 PM
  #1145
Kidloco51's Avatar
2250 what the ****?????
Old Apr 8, 2012 | 08:49 PM
  #1146
B.J.@ToxicFab's Avatar
I remember seeing pics of this car from a couple yrs ago & I think it weighed around 2500lbs or so...2250lbs is ridiculous!! Post pics please!
Old Apr 8, 2012 | 09:39 PM
  #1147
redrocket03's Avatar
Originally Posted by evodan2004
give us a list of what you have done. also to what extent you want the car to see. i am more then willing to share everything i did except my own secrets or someone else's who have asked me to keep it to my self.
right now my car sits at 2830 no driver and with a cage. thats 140lbs lighter then last year. i still can get another 60/75lbs out of it but my pocket needs to take a break. haha. i am on to the next stage of remodeling part of my house so big funds are cut for the car. with the new turbo and weight savings i expect huge gains so before i go nuts i want to see what it does.
Ok so far I have got rota slipstreams with hoosier qtp
-all ac stuff gone
-front and rear bumper supports gone
-sound deadening out all of it
-ams lightweight crossmember
-buschur moustache bar
-carbon fiber hood and trunk wingless
-entire trunk stripped even the springs for the trunk lol
-rear wiper assembly and tank
-fmic sprayer and stuff
-intake bracket and egr
-evap canister removed
-half size radiator with slim fan
-awd aluminum driveshaft
-buschur lightweight exhaust with test pipe
-buschur small battery
-aluminum intercooler piping
-steering column metal insert
-floor mats are out
-driver side air bag
-front wiper arms (still have motor)
-all oem seatbelts are gone (have harness bar with harnesses)
-torque solution motor mounts and tranny mounts(seem a little bit lighter)
-dust shields are gone
-all padding under carpet is gone
-front tower brace removed
-lightweight lugnuts
-d2 awd coilovers
-some wiring taken out under hood for unneeded stuff removed
As far as I know I can still do small brakes, carbon fiber roof(I still have sunroof), remove heater stuff, nrg or sparco seats, br lowering brackets, drop down to 15 inch wheels after small brakes, abs delete, remove passenger air bag, wiper motor in front, and the exhaust shields under the car. I would like to save the dash removal for the winter so what can I remove fairly easy at first and save the hard stuff for winter? Im trying to still have the street car image as its called haha but im sure in the end Ill change my mind. I dont really have any weight goals but just to be as light as possible without breaking the bank. Any help would be greatly appreciated. What all can be removed without removing the dash? I plan on the br lithuim battery when my dies and dont plan on a cage being its still a street car.
Old Apr 9, 2012 | 05:01 AM
  #1148
^^^Thats a pretty good list...Have you weighed the car recently? You have to be somewhere in the 2800lb range at least...
Old Apr 9, 2012 | 07:37 AM
  #1149
Evo8RA's Avatar
Be happy to as soon as I get it back together. It's currently on jack stands having the AST coilovers reworked and mounting the 350lbs of ballast low. Alternatively, I might be able to get some from the guys at COBB later today.
Old Apr 9, 2012 | 08:20 AM
  #1150
blackgsx01's Avatar
How much weight do you save removing your abs? Or converting acd to non-acd t-case while removing your pump/lines/computer? I hope to do these things a little down the road to clean up engine bay and cut some weight
Old Apr 9, 2012 | 08:52 AM
  #1151
Removing all the ACD stuff drops 30lbs+...not sure on the ABS though...
Old Apr 9, 2012 | 08:57 AM
  #1152
badev0's Avatar
You don't save a whole lot removing the ABS. I would say 9lbs at most but that's pushing it.
Old Apr 9, 2012 | 11:30 AM
  #1153
EvoDan2004's Avatar
-all ac stuff gone
-floor mats are out
-d2 awd coilovers
seems like your on the right track. its at that expensive stage now lol
Old Apr 9, 2012 | 01:49 PM
  #1154
Evo8RA's Avatar
Here’s a picture minus the front bumper cover, 5-lb carbon hood and carbon trunk. Roof is polished aluminum. There are some closeup pictures in the link found at post #324 on pg 22 in this thread. They were taken back in 2008 when most of the work was done and the car weighed around 2320. I've also described some of the details on pg 21-23. Wheels are 16x10", so you can see the car is quite low. Most of what’s been done since then has been small stuff to get to 2250lbs.
Attached Thumbnails Post exact weights of weight reduction you have done!-berry_evo8.jpg
Old Apr 9, 2012 | 02:27 PM
  #1155
Lol nah I haven't weighed it yet I meant to the last time at the track and I forgot all about it cause I had some minor setbacks then I blew my headgasket haha. The car is in the shop now waiting for a headgasket to come in so this will be a good chance to get some more weight outta her. I guess I'll weigh next time out you really think 2800 range? I would prolly settle for that for now but wouldn't be able to sleep knowing I can get more out haha this thread has got me whipped. Any suggestions or ideas would be greatly appreciated. Ima save all the big stuff for the winter
