Post Your Custom Sub Enclosure Here!
Old Apr 25, 2007 | 07:53 PM
  #91
edgard's Avatar
Originally Posted by 4g64T
very nice setup..whats the rms on that sub?
rms is 1000 watts and the max is 3000 watts. Right now i have it wired to a 1600 watts amp and its takes it fine. i think it coould take up to 2000 its a great sub a little pricey but youll never need another one.
Old Apr 25, 2007 | 08:13 PM
  #92
boostinpsi's Avatar
im trying to fit 2 12s into my trunk. anyone got ideas. i think it would cool to have them mounted like msconsoli's box but how would you go about making the pass. side box?
Old Apr 26, 2007 | 05:20 AM
  #93
geminibby's Avatar
if you dont plan on putting in a rear strut bar, why not have them firing into the cabin? only other option would be in the tire well.
yes the rms on alpine type x 10 is 1000, I have the pdx 1.1000 which is actually rated at 1600. I do agree that it will handle much more...as far as the price, it depends on where you go. I usually get my stuff from a wholeshare dealer here in FL, but I got a deal on the amp and speaker combo for 694.
Old Apr 26, 2007 | 02:32 PM
  #94
MConsoliA4's Avatar
As for mounting our box, you can drill a 3/8" hole through the floor and bolt it in from up under the car and seal it well and i guarantee you that thing's not going anywhere.
Old Apr 26, 2007 | 03:00 PM
  #95
TempeRacerGuy's Avatar
I'm very interested in this box. However I would like one for the passenger side as well. Is there plans to build a passenger side unit to match?
This is a bit too small for the 12s I would use (they need 1.25cuft), so I am looking to use 10s, and fill in the back wall or base with resin to lower the volume. What other "filler" do you suggest that's not so heavy? I need to bring the internal volume down from 1 cuft down to .63 ftcu.
Old Apr 26, 2007 | 03:55 PM
  #96
o6RSEvo's Avatar
What kind of sub is that?
Old Apr 26, 2007 | 04:11 PM
  #97
JL Audio 10W3V2 300W RMS, .625 ft cu ideal sealed enclosure volume. .05 Driver displacement... so recalculate my numbers (I misplaced a decimal space), I need .675 ft cu
Old Apr 26, 2007 | 04:25 PM
  #98
Hmm, now that I am thinking... I may be able to add a 2" port to this box and tune it to 33.4 HZ for a nice sounding system with a clean look...
However to even consider this box, I would need a matching Passenger side.
So, any plans for a passenger side? Otherwise I may just have to glass my own.
Old Apr 27, 2007 | 11:48 PM
  #99
SpineDoc's Avatar
Originally Posted by fostytou
For everybody looking at the MconsoliA4 box I'm looking for a modular but very secure way to get this thing in there... it seems to stay pretty well, but I want some hardware to keep it in. I don't imagine I'll ever upgrade, this thing looks great... so welding is not out of the option
So far the best Idea I have really come up with is a gravity latch (for a gated fence) that could latch onto a U ring welded into the floor. It seemed like the perfect solution until I got the box. It looks like the only way for it to really come out is to slide from the drivers side to the passengers side, or to swing from the front (of the vehicle) corner.
Anybody have any other good ideas?
I took a large "L" brackett (sp) and removed the cover on the side trunk. this allowed me to secure it to the metal support and stuck out enough to secure w/ a wing nut in box, no holes in trunk=no leaks
Old Apr 28, 2007 | 06:25 AM
  #100
MConsoliA4's Avatar
There are no plans to make a passenger side at this time. Mostly due to the symmetry of the trunk (or lack of) so the boxes would not match. Plus we've found from making about 40 different "Magic Boxes" that when you build a passenger side, the customer wants a driver's side, and build a driver's side customers want a passenger side. You build both and the customer wants them to fit 15" woofers. So the easiest way to make the most people happy was to take the larger side and recess it at much as possible.
I'll tell you guys this much though... If we can get at least 5 people to commit to buying a passenger side if we build it (sorta like a pre-order thing), then we'll get another Evo in here and make it.
Old Apr 28, 2007 | 10:25 AM
  #101
fostytou's Avatar
EvoM Community Team
Any chance you could PM me some pics of that, it would be awesome!
Old Apr 28, 2007 | 11:36 AM
  #102
boostinpsi's Avatar
another question haha. i gave up on my 2 12s. sat in a guys car who had 2 12s and it was way too much. so im looking for 1 12. id do it this summer and would probably be buying this custom box. does it have enough arispace for an alpine type-R?
also can you pass autox tech with this box if its bolted down along with the amp bolted to the back of the seat?
Old May 1, 2007 | 06:49 PM
  #103
JDMBIGGIE's Avatar
Damn this is alot of extra weight...
Old May 1, 2007 | 08:35 PM
  #104
OK, anyone else in for a passenger side box? I'm one!
Old May 2, 2007 | 05:44 AM
  #105
geminibby's Avatar
yeah I agree, but that looks tight. props for the install.
