help me write a DIY for compustar 2w900fm-as alarm on a 2006 EVO MR!!
The reason I asked, cuz you describe positive trigger locks and evos are negative triggered locks. I found both of my lock/unlock wires in the same plug. They weren't together in that plug, but they both were there. IIRC one of them was the bottom middle wire and the other was somewhere towards the top of the plug (actually looking at the plug}. I'm pretty sure they're in the white plug towards the floor that clips to something else. It popped off the clip fairly easily.
Has it ever worked?
Has it ever worked?
Sounds like you tagged a motor wire instead of a switch wire.
I can't remember the wire color of hand, but both wires should rest a 12 volts using a DVM and switch to zero when you hit the switch. Do this at your own risk, you can use a regular test light to probe the wire and when you find the right one, it will lock or unlock depending on the wire your tagging. There is not a whole lot of CAN data going on in an Evo in the doors so you should be OK.
As for DLS, I get what your saying. But I alwyas use a relay over a diode if i can. I feel you about wiring extra relays, I hate it too, but I know they work.
What i wrote above about interupting will work for you too, just need the relay and 4 wires. Git R done!
Actually you should be able to do it with one relay. I haven't thought it completely through so everything may not work. 85 = 12v; 86 = DLS; 30 = car door trigger from plug; 87 = car door trigger away from plug; 87a = ground. Connect alarm door trigger wire downstream of 87 and when DLS activates it will switch 30 to ground (87a) controlling the domelight while still protecting doors and the alarm won't see a false door opening.
30 and 87a is the closed part so you would be grounding your door trigger while resting. But you can do it with one relay
87 - ground
87a - door trigger to alarm side
85 - 12volt
86 - DLS
30 - door trigger/car side
While resting it will provide protection for the door circuit. When disarmed, the relay will open the door circuit to the alarm, relay will close 87 and 30 and ground the door circuit to turn on the interior lamp
87 - ground
85 - 12volt
86 - DLS
From the12volt.com
2005 MITSUBISHI LANCER 4DR SEDAN EVO VIII
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger WHITE (-) FUSEBOX , WHITE PLUG AT BOTTOM
Domelight Super USE DOOR TRIGGER
Trunk Trigger GREEN/ORANGE (-) TRUNK LIGHT
Alarm Disarm GRAY
Parking Lights GREEN/YELLOW (L) GREEN/WHITE (R) (+) FUSEBOX , WHITE PLUG AT BOTTOM
Convenience
Headlights-Lo RED/YELLOW (L) PINK (R) (+) RELAY CENTER UNDER HOOD
All Hazrd Lights WHITE (-) HAZARD SWITCH
Wipers-Lo BLUE/RED (+) WIPER MOTOR
Wipers-Hi ORANGE (+) WIPER MOTOR
Parking Brake BLUE/RED (-) PARKING BRAKE SWITCH
Remote Start
Accessory 1 BLUE/BLACK (+) IGNITION SWITCH HARNESS
Accessory 2 BLUE/WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type SOME MODELS HAVE RF TYPE IMMOBILIZER SYSTEMS
Key Sense BLUE
RESTS AT GROUND OPEN WHEN KEY IS IN, USE RELAY TO OPEN.
Tachometer BLACK/YELLOW (-) IGNITION COIL
Speed Sense BLACK/RED (AC) DIAGNOSTIC CONNECTOR UNDER DRIVER DASH
Brake Lights GREEN (+) BRAKE SWITCH
Reverse Lights BROWN (+) DRIVER KICK PANEL, HARNESS TO REAR
Horn BLUE/RED OR RED (-) HORN SWITCH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock LT.GREEN (-) DRIVER KICK DOOR HARNESS
PowerLock VIOLET (-) DRIVER KICK DOOR HARNESS
Driver Mtr Unlock WHITE (REV) DRIVER KICK DOOR HARNESS
Driver Mtr Lock BLUE/RED (AC) DRIVER KICK DOOR HARNESS
LF Window Up RED/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
LF Window Dn GREEN/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
RF Window Up BLUE/WHITE (REV) DRIVER KICK DOOR HARNESS
RF Window Dn BLACK/WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Up WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Dn BLUE (REV) DRIVER KICK DOOR HARNESS
RR Window Up BLUE/BLACK (REV) DRIVER KICK DOOR HARNESS
RR Window Dn GREEN/YELLOW (REV) DRIVER KICK DOOR HARNESS
Security
Alarm Disarm GRAY
Convenience
Remote Start
Key Sense BLUE
Modules
WIRE LOCATION
Doorlocks/Windows
Just purchased the Compustar 2W900FM-AS and I am going to attempt the install during the next couple of weeks. I will write down any useful information I determine during the install.
johnjonfenomeno
178
Jan 7, 2026 09:18 PM
Ancyker
22
Apr 4, 2016 04:58 PM
t mac
Jun 16, 2012 04:23 PM
sblvro
Dec 20, 2006 07:39 PM
