Capacitor wiring...
Old Jul 21, 2007 | 08:26 AM
SyZyGy1394's Avatar
Capacitor wiring...
I have a question reguarding to a capacitor. Can i run the ground from the - on the amp to the - on the cap and then to the frame or do i have to run the amp's - and cap's - seperately to the frame?
I'm just a little confused on whether how to wire this capacitor...
Old Jul 21, 2007 | 08:50 AM
FedEvo8's Avatar
I ran my amp ground directly to the capacitor ground. Then grounded the capacitor to the frame.
Old Jul 21, 2007 | 10:06 AM
Jameson_IXMR's Avatar
You sure can, theres no problem with that.
Old Jul 21, 2007 | 11:01 AM
SyZyGy1394's Avatar
Thanks, I appreciate it!
Old Jul 22, 2007 | 12:56 PM
SyZyGy1394's Avatar
Oh yea one more thing. Do you know to what voltage i am supposed to charge this capacitor up to? Because I've heard a few places say 11, or 12?
Old Jul 22, 2007 | 01:49 PM
What type of cap? Have you checked the manufacturers website?
Old Jul 24, 2007 | 07:08 AM
gerthiekins's Avatar
ya check the manufact sometimes they require you to do it certain ways but then again its probbaly ok.
Old Jul 25, 2007 | 08:59 PM
YtDiamond05's Avatar
Usually the cap comes with a little bulb that you put in between the positive and negative terminal. Or also a little white resistor that charges the cap. Then just remove when the bulb goes out and you are good to go!
Old Jul 26, 2007 | 11:18 AM
st3alth5's Avatar
The resistor is usually nothing special. Just a 1000 ohm resistor. If you use a resistor be careful not to touch the leads while the capacitor is charging, because those suckers get freaking HOT! (speaking from experience)
Old Jul 26, 2007 | 11:50 AM
b00stin evo8's Avatar
all depends on the cap. Some need to be self ground and the amp will have to be also. Some you can just put both negatives on the cap and be fine check the manual
mx4life85
Mar 12, 2011 02:41 PM
darkknight
Sep 10, 2010 07:09 AM
n0ob
Mar 8, 2008 01:10 AM
PurEvo
Feb 8, 2007 06:27 PM
OZLancerlunatic
Lancer Engine Tech
Feb 5, 2002 11:53 PM
