DIY: Viper 5701 Install on CT9A
Im assuming you mean the turbo timer feature?
If you are in turbo timer mode the car will be armed and still running. To enter turbo timer mode, go through the manual start procedure, footbrak,handbrake,footbrake release, then open your door, hit "F" 2x, then the autostart sequence. You will see that upon arming the vehicle it will still be running for whatever length you specified on timer mode. I think I have mine set for 3 minutes.
see the thing is I have an aftermarket turbotimer. Hey man I was wondering If you can do me a HUGE favor! Can you do a write up on my car. Its a 1997 mitsubishi eclipse gsx 5 speed. I cant seem to get my door trigger to work either. Im using the wire that gives off a + feed when open. I believe. I did. If you have time that will be DA BOMB! thanks john
Door triggers are pretty much always negative. This is for your eclipse. Sorry it's hard to read, I just copied and pasted.
Constant 12V+ White Ignition Switch Harness
Starter Black/Red Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Ignition 2 Blue Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach Black/Blue Or Blue/Black Coil Pack 2 Cylinder Setting
Neutral Safety Wire Black/White (-) PCM behind Center Console
Brake Switch Green Brake Switch
Trunk Pin Red/Green Driver's Running Board
Parking Lights Green/White (+) Driver's Kick Panel or Fuse Panel
Head Lamp Red (-) Light Switch
Factory Disarm Red/Green (-) ECU Passenger's Kick Panel
Door Trigger Red/Green (-) Courtesy Light or Driver's Kick Panel
Door Lock Brown (-) Behind Fuse Panel or 20 Pin Connector High Driver's Kick Panel
Door Unlock Brown/White (-)
Driver's Lock Blue/Black Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Blue/Red Passenger's Kick Panel
Horn Wire Green/Red (-) Steering Column
Windows Up LF=Green/Red, RF=Brown/Yellow
Windows Down LF=Green/Black, RF=Green/Yellow
so is it if I tap into the Neg door trigger then it should read a -12 if I hooked up a volt meter to it with the positive pen of the volt meter on that side. Sorry If i didnt make sense right there.
No. A negative trigger reads 12volts (+ or - depends on how you hook up your dmm) at rest then goes to 0 when it's triggered. So for the doors it would show 12v with the door shut and go to 0 when it opens.
Ok so I got everything working BUT the REMOTE START! I tried doing the manual setup. Where I have to
1.shut the door
2press the breake
3pull the ebrake(dosnt know if that has to do with the alarm, for it to start)
4 release the brake, and with in 15 seconds press the remote start on the alarm
5.Turn the ing off
6step out of the car
7arm the car and it should shut off
Well I get to about step number 4 and nothing happends
I get Lock and the F lights on the remote come on. And the lights flash 7 times on my parking lights. On the manual it says that I have to initiate. But thats what ive been trying to do!! Oh yea, I also did the tach learn and that came out fine I believe
1.shut the door
2press the breake
5.Turn the ing off
oh yea i even have the toggle switch on. the one on the module. And If I read correctly I dont have to have the manual saftey wire hooked it because I have a 5 speed?
I was trying to, but I get up to when trying to set the car to manual mode, releasing the brake and pushing the remote start button the the remote and i get an error signal. And then thats when my parking lights flash 7 times.
Are you sure your e-brake and foot brake signals are coming through and you tapped the correct wires?
I don't have the nutural saftey wire,and hood pin connected to anything. I thought if it was a 5 speed you don't hook up the netural saftey wire. And for the hood pin wire. I don't touch that if I don't want it?
Black/white wire on harness2 to your ebrake light dunno what it is on a eclipse
