the easiest solution to relocate you climate control for 2din display
Old Jan 20, 2011 | 09:03 PM
  #211
ayothatsdanny's Avatar
is there a way to relocate the HVAC without buying the radio relocation kit?
Old Feb 4, 2011 | 11:05 PM
  #212
shangai's Avatar
Dont know, but i have done radio relocarion without the kit
Old Feb 7, 2011 | 10:55 AM
  #213
MidniteEco's Avatar
You can, but it probably won't look pretty. For mine, I just bought some screws and spacers at the local hardware store. (I got the bezel for the lower section from someone that had it on a Lancer.)
Old Feb 7, 2011 | 06:41 PM
  #214
MidniteEco's Avatar
I followed these great instructions to do my install and spent hours trimming the pieces to fit just right. Now I'm selling my kit since I sold my Evo: Double Din Radio Install Kit
Old Feb 7, 2011 | 11:37 PM
  #215
Quesadilla's Avatar
Looks like a ton of work ...and bravery.
Old Feb 25, 2011 | 04:00 PM
  #216
xlilvtbo1x's Avatar
looks nice
Old Mar 13, 2011 | 07:04 PM
  #217
dizaryl's Avatar
It's not that easy. I just did this upgrade and was so proud of the panel before mounting. I had planned on using spacers instead of tension fitting with the face plate, but I couldn't get the right fit. For greater fudge factor I would recommend over drilling the bottom factory holes to accomodate allthread and nyloc nut combinations. Allthread can be cut to length and nyloc nuts hold at any position on the allthread. Also allthread of that size (1/8" to 3/16") can be easily bent to allow you to even use the bottom of the climate contol holes change the pitch of unit for better fit.
Old Mar 14, 2011 | 05:47 PM
  #218
dizaryl's Avatar
Reread most of post and it is way easier to disconnect the hvac cables from underneath driver side dash than from the top of the hvac controls still hooked to it. Needle nose pliers and tweaker screwdriver for the cable ends. Spread clamps and pull out cable from anchor points. Took 2 minutes.
Old Mar 14, 2011 | 05:56 PM
  #219
cyanide's Avatar
If you don't use temp and vents control often, this could be a solution:
The blower motor switch was placed in the car lighter hole, and the rest of the controls were left inside the dash, behind the radio.
Old Apr 11, 2011 | 05:10 AM
  #220
grey~ghost's Avatar
I'm definitely trying this but instead of a double din I want to mount 6 gauges and relocate my radio to the trunk, i could just use blue tooth from my iphone. I need to construct a 6 gauge panel. Has anyone though of this or attempted this?
Old Apr 11, 2011 | 06:14 AM
  #221
cyanide's Avatar
No need to go all the way to the trunk. Mount the radio under the drivers seat. The pic above your post shows an lcd which was connected to a single din dvd player mounted under the passenger's seat. Modify the radio trim, or get the japanparts 2 din, and you'll get your space.
Old Apr 12, 2011 | 09:31 PM
  #222
joey110892's Avatar
looks sick
Old Apr 17, 2012 | 09:29 PM
  #223
BCMason's Avatar
Doubble Din
So i have done a lot of reading and still no luck in finding an answer.
Is there a double din conversion kit for the 03 lancer you can buy for the climate control?
Old Apr 18, 2012 | 04:43 AM
  #224
cyanide's Avatar
If you can't find an answer, then you haven't read enough. There are plenty of threads on evom alone regarding 2 din conversions and hvac relocations. Maybe you need to change your search keywords...
Old Apr 20, 2012 | 09:22 AM
  #225
mrboost05's Avatar
can anyone point me to a site or local store where i can get something to hold my dd still i am using the factory radio mounts on my jvc dd headunit there is just nothing to hold the screws still ill post pics to help if they are needed thanks guys i tried pep boys best buy and autozone with no luck.
