High output alt for decent price?
Old Apr 14, 2011 | 07:28 AM
seanjohn291's Avatar
Hey guys, I was curious to see if anyone knows of/ uses a high output alternator that would be good the evo 8. I'm currently running two amps in my car, 1800 watts total, and at full volume the lights dim and my voltage meter drops when the bass hits so I can't fully "enjoy" my sound system, thanks in advance!
Old Apr 14, 2011 | 08:39 AM
Bobster22388's Avatar
Why not just get a capacitor put in?
Old Apr 14, 2011 | 08:55 AM
Marcac's Avatar
I'm sorry if I step on any toes but don't get a capacitor!! This is for a few reasons.
1: A capacitor gives you no additional production of power just a little more storage area. A capacitor can also charge and discharge faster than a battery however this is rarely enough to fix the issues at hand.
2: If addititional storage will fix your problem a better battery (Optima Redtop or yellowtop) or even an additional battery in the trunk can be purchased at a similar price as retail on a good capacitor and has WAY more storage than a cap. But even this doesn't solve the production issue.
Therefore if you are using more power than your car is making, whether you use a cap or an additional battery, the only good solution is like you are thinking, increse the electrical output of an alternator. In my opinion Caps, and even additional batteries to an extent, are only a band-aid, they help the problem but don't fix it. That being said I have no experience with upgraded alternators on the evo so...
Good luck
Old Apr 14, 2011 | 05:53 PM
Yea I wasnt going to get a cap for that reason, I was thinking about an Optima Red-top but im not sure, no experience with those batteries but i've heard good things. I havent seen anyone using an upgraded alt on an evo so i was just throwing this out there to see if anyone had an idea
Old Apr 14, 2011 | 11:36 PM
DSM2EVO's Avatar
hope this helps
http://shop.douglasautoworks.com/Cha...ystem_c109.htm
Old Apr 14, 2011 | 11:48 PM
Pal215's Avatar
Wow that's a hefty alternator. Now my question is, would a high output alternator put more drag on the engine?
Old Apr 15, 2011 | 06:57 AM
Oh sweet, thanks man, i believe the OEM is around 90amps but dont quote me on that.
^ i would like to know that as well
Old Apr 15, 2011 | 12:10 PM
DSM2EVO's Avatar
yeah the oem is 90 amps i also want to order this one as well since im doing big audio but also heard dominick irraggi are way better if you can get one he has 3 sizes
Old Apr 15, 2011 | 02:49 PM
i didnt know irraggi ones for mitsu, ill check that out
to DSM2EVO, what are you puttin in your car?
Old Apr 15, 2011 | 07:31 PM
DSM2EVO's Avatar
old model jl 1000x1, eclipse 4 channel amp xa4000,focals 3way components with tweeters and crossovers,jl wiring kit,boss 20 farad cap,pioneer radio deck wanted double din but not willing to part gauges and relocated audio and climate bezel and last an eclipse 2000watts sub titanium with heavy duty magnet
Old Apr 16, 2011 | 02:23 PM
dizaryl's Avatar
75d
Optima sells a yellow top battery specific for cadillacs with both side posts and top posts. (The fitment with the top post fuse holding positive I have yet to takle) The top post factory fuse holding 90 blocks the side post, but if you have a stereo like that I'm sure you have bent a wire or two. If the alternator doesn't fix the problem I would lean towards the optima. I've had these before and they are great. Note; you can not charge an Optima with an el cheapo charger since they are a spriral cell. Charging any other way will toast the battery. The 75d? has the same footprint as the 75, but has side posts in addition. Just a thought.
Aug 11, 2015 08:07 PM
WikdEvo
Mar 18, 2014 07:51 PM
JDMonster
15
Feb 8, 2013 02:39 PM
Nastynine
Apr 10, 2010 05:45 AM
03lancOZ
Sep 13, 2004 06:50 PM
