LED Brakelights stay lit with ignition on
Old Jul 20, 2013 | 03:10 PM
shadow1's Avatar
So I've tried multiple 7443 LED bulbs from different vendors and they all suffer the same thing. The tail/brake lights are dimly lit with the motor running with the lights off. They otherwise work normally. I measured the voltage in the circuit with the motor running (lights off) to be 2.9-3 volts which is enough to partially light an LED bulb but not an incandescent bulb. Any suggestions to make the LED bulbs work?
Old Dec 4, 2013 | 04:40 PM
Lion_Sam's Avatar
I'm have small LED lit on rear spoiler. But I'm ignored it till AYC ECU not started to show error "61 Stop Lamp Switch".
AYC ECU also show what brake pedal is always pressed, so it's about small voltage at input. Tried to disconnect brake pedal switch and plug under rear sit - no effect. And funny thing - disconnecting AYC is turning off LED lit on rear spoiler, ha.
Also tried to replace AYC ECU - no changes.
So, haven't time to search where it can get some connection with 12V or something. But solved AYC DTC by connecting 3-4kOhm resistor to ground and brake pedal switch input. AYC now can normally see brake pedal switch position.
europaul
Mar 16, 2016 10:54 PM
dailydriven09
Lancer Troubleshooting
10
Oct 21, 2014 07:35 PM
MagicManRed
Jun 27, 2011 04:22 PM
czapski
Canadian Forum
Nov 23, 2008 03:41 PM
