View Poll Results: RPM raise between shifts?
YES --- Modified ECM (includes all after market EMS and piggyback and flash ECU)
93
30.49%
YES --- Modified clutch (all aftermarket clutch)
71
23.28%
YES --- Modifed MAF (convert to speed density)
18
5.90%
YES --- Modifed BOV (all after market BOV now or tried before)
91
29.84%
Yes --- All stock on above parts
95
31.15%
Not at all (includes stock or modified)
76
24.92%
Multiple Choice Poll. Voters: 305. You may not vote on this poll
Old Nov 19, 2004 | 02:09 PM
  #46
bolsen's Avatar
edit: I was wrong
Old Nov 19, 2004 | 02:22 PM
  #47
Turboholic's Avatar
can you explain how to solve that?
https://www.evolutionm.net/forums/sh...ht=boost+creep
that's exactly what happen like someone post over there,
rpm and boost keep increase until my boost guage hit 1.5~1.6bar before the rpm drop.
Old Nov 19, 2004 | 08:11 PM
  #48
titaniumkingpin's Avatar
does anybody have a fix? my car just started to do this and its NOT driver error.
also, i haven't done any modding in months and it drove fine. now it jumps 500 rpm in between shifts when on boost.
Old Nov 19, 2004 | 08:18 PM
  #49
Turboholic's Avatar
try check your bov dumb tube, check all the clamps and coupling for the ic pipes,
Old Nov 20, 2004 | 02:15 AM
  #50
anyone else have any idea?
Old Nov 20, 2004 | 10:39 AM
  #51
bolsen's Avatar
Hmm guess I used the wrong term, my bad
Old Nov 21, 2004 | 11:36 AM
  #52
plokivos's Avatar
this happens with a completely stock evo, it's not the aftermarket bov.
I'm thinking it's the way the stock clutch is wearing. Seems like all the people who's having this problem have the stock clutch with relatively high milage (20k ~ 30k),
Someone figure it out.
And check the links, all this have been discussed before,
Old Nov 21, 2004 | 03:58 PM
  #53
bpclements's Avatar
I have the problem even with my clutchmaster stage 3. I do have 26,000 miles on it though.
Old Nov 21, 2004 | 07:16 PM
  #54
93civEJ1's Avatar
going on 31k on my stock clutch.
Old Nov 21, 2004 | 11:24 PM
  #55
talked to a mitsu tech and they say it might be the throw out bearing.
has anyone noticed that when reving the engine in neutral at a stop, the engine makes a slight whinning noise? and try pressing the clutch in and then rev, does the noise go away?
this noise may be connected to this other problem. going to mitsu dealer to check tomorrow morning. i will repost tomorrow.
Old Nov 22, 2004 | 01:05 PM
  #56
plokivos's Avatar
Yeh, the throw out bearing is wearing out is something that came up and I think thats what it is.
Old Nov 26, 2004 | 04:15 PM
  #57
sorry, but i want to bring back this thread.
i just changed my clutch and throw out bearing. rpm still raises!!!!
im stumped.
anyone think it has to do with my reflash?
Old Nov 26, 2004 | 10:29 PM
  #58
Turboholic's Avatar
i already said that there is nothing to do with the clutch,
i have not confirmed that the ECM problem since Martin has not get back to me about my AEM calibration,
however, in my case, i am not saying anyone else, there is something to do with the BOV, and i will change back to stock bov and see,
might have something related to the weather too.
Old Nov 27, 2004 | 10:07 AM
  #59
93civEJ1's Avatar
no its not the bov either, i drove around with stock BOV and it still happened. I only noticed mine start to happen after popping off a vacuum hose off the intake manifold from boost pressure.
Old Nov 27, 2004 | 03:15 PM
  #60
yeah, i don't think its the bov because i switched out to the stock and it still does it.
lets put our heads together and find a damn fix.
i know that its not CLUTCH or THROW OUT BEARING
i know that its also not the BOV
what about ECU. i got dynoflashed a while back.
