Quick parts updates....
Old Apr 19, 2005 | 12:15 PM
  #301
alex_alex's Avatar
Originally Posted by JeffR116
Quick questions regarding your mail in flash: The revlimit is set for 8500 as a default setting on your mail in flash. Are you recommending upgraded valve springs/retainers for the 4g to rev that high? Also I'm assuming you can set the RPM limit lower.
Thanks!
Jeff
Isn't 8500 a bit high?
Old Apr 19, 2005 | 01:24 PM
  #302
Derek Baker's Avatar
I thought that the revlimit was 7,800
Old Apr 19, 2005 | 01:26 PM
  #303
Kwman's Avatar
I love this thread.
Old Apr 19, 2005 | 01:44 PM
  #304
EVO8LTW's Avatar
Wuss. I rev to 8500 everyday, 12.5:1 AFR and 27 psi on pump gas.
Old Apr 19, 2005 | 01:50 PM
  #305
JeffR116's Avatar
As quoted from the Buschur Site:
BUSCHUR FLASH CUSTOM ECU TUNING
Buschur Racing offers custom tuning using your stock ECU, and a list of your modifications available through the mail. The information in your stock ECU is replaced with a setup to run your aftermarket performance parts, and in the process removes your fuel cut, speed limiter, and raises the rev limiter to 8500rpm. Price also includes overnight air shipping back to you. If you have any questions or concerns about doing this please contact us.
Price:
$375.00 Stock #: EVO-40000
Old Apr 19, 2005 | 07:24 PM
  #306
trinydex's Avatar
dangit... i'm so impatient... i need to dream of having a 20g on my car... dave... make my dreams possible! pics? maybe... anything...
Old Apr 19, 2005 | 11:00 PM
  #307
IS2000's Avatar
Yes, I want this turbo now!
Hofefully, it works well like what I'm expecting.
Old Apr 20, 2005 | 12:04 AM
  #308
trinydex's Avatar
ugh... checking for david's midnight update table scraps...
Old Apr 20, 2005 | 12:37 PM
  #309
inariv5573's Avatar
Will this 20G be a TRUE bolt on? Meaning it will have an internal wastegate since it uses a stock like turbine housing? I would hate to go to external. In which case I would stick with stock turbo, or get TME.
Old Apr 20, 2005 | 01:50 PM
  #310
Corey's Avatar
From what I thought, this is suppose to be a direct bolt on using everything the stocker used. You might have to upgrade a few things like injectors and such, but it should dbe bolt on.
Old Apr 20, 2005 | 03:40 PM
  #311
Erik@MIL.SPEC's Avatar
It is a direct bolt on. It's the stocker with a 20g compressor wheel. Everything else is the same unless you want to upgrade to a Ti turbine wheel or something...
Old Apr 20, 2005 | 09:54 PM
  #312
trinydex's Avatar
it's actually a bolt in... if you want to get yours put in... but there's a swapping deal... your core plus more money for the 10.5 plus wheel in ti/al
Old Apr 21, 2005 | 11:42 PM
  #313
YellwTyper's Avatar
Looking for bump-er
Old Apr 22, 2005 | 08:12 AM
  #314
David Buschur's Avatar
We do not have to re-set the revlimiter if you don't want it changed. 8500 rpm hasn't been a problem, OCCASIONALLY. These engines are SO strong.
The 20g is a direct bolt on, looks just like stock.
I haven't tested yet. So busy.
David Buschur
www.buschurracing.com
Old Apr 22, 2005 | 08:26 AM
  #315
Derek888's Avatar
So everything is direct bolt on right? I want to keep the stock turbo and just buy a 20g. Everything else in the car stays stock like O2, dp etc....?
