Quick parts updates....
Old Dec 19, 2004 | 12:09 AM
  #106
David Buschur's Avatar
No new news. This local guy here is really busting *** on this project though and to be honest might come through before these shops that have been working on it for the last year. I hope so.
I cannot upgrade a stock turbo to a Ti/Al turbo. I will probably take stock perfect condition turbos in on trade towards a brand new unit though. I have been buying up stock turbos, manifolds and 02 housings when I can get them at a good price lately. We have done some pretty extensive porting on the parts and have sent them out for ceramic coating. When they come back I am going to do some testing on them and see what kind of gains we can get from just the port work. Last time we did this, on our 2003, we just went in and cleaned them up a little. There were no gains on the dyno. This time we made some fairly major changes in how we ported the parts and are expecting to see something from it.
If and when it all works out we will be offering the parts ported and ceramic coated.
David Buschur
www.buschurracing.com
Old Dec 19, 2004 | 05:56 PM
  #107
lil'evil_evo's Avatar
Originally Posted by spoolingEVOx
for the record, i definitely plan on purchasing one of these modified factory turbos. in fact, i am hoping we can use the 20G compressor/Ti wheel on the newer MR/GSR 10.5" compressor housing so that i could also benefit from the improved wastegate.
my question is this.. i am planning on purchasing a downpipe soon, and it will be mated to an HKS Hi-Power catback. what size downpipe should i go with if i will be using this modified turbocharger as well as the catback that i already have? i am torn between the HKS, Fujitsubo, and Works systems.. what are your thoughts?
Buschur or Helix
Old Dec 20, 2004 | 05:15 AM
  #108
MalibuJack's Avatar
I think people are just getting confused by terminology..
and before anyone gets completely confused, almost everyone who is talking about this is talking about the 10.5 turbine housing..
The exception being myself, since I purchased a compressor cover to see if there was a difference.
Wastegate Actuator is the brass looking vacuum cannister thing on the turbo
Wastegate Solenoid is the BOOST solenoid
Compressor cover is the cold side of the turbo (nobody has to change this)
Turbine Housing (10.5) is the hot side with the revised wastegate flapper.
Wastegate/Flapper is part of the turbine housing on this turbo.
20G or 16G is the compressor wheel
then there's the Impeller, or Turbine wheel (exhaust wheel) which can be had in Ti/AL
Hope this clears up any confusion.
Old Dec 20, 2004 | 06:50 AM
  #109
JustDSM's Avatar
Good idea to clear that up. I was typing a little slower than my mind was thinking.. I had intented to say the wastegate actuator was the same as well as the solenoid, but it didn't come out that way. Regardless... You cleared it up nicely.
Old Dec 21, 2004 | 01:09 PM
  #110
jj_008's Avatar
What is the difference between this modified 20g and a run of the mill 20g from mitsu (besides reverse rotation)? Some guy on the lancer registry had a 20g w/ his greddy turbo kit and it was a lot laggier then the stock turbo.
Old Dec 21, 2004 | 01:12 PM
  #111
Terry S's Avatar
Perhaps the hot side is smaller and more efficient? (wild guess)
Old Dec 21, 2004 | 01:18 PM
  #112
Kaane's Avatar
normal 20g runs a Td06 turbine wheel which is much bigger, the hybrid turbo still uses the td05 turbine wheel, Also the real 20g has much large compressor cover.
Old Dec 21, 2004 | 01:19 PM
  #113
Kaane's Avatar
normal 20g uses a different turbine housing as well, not twin scroll.
Old Dec 21, 2004 | 01:32 PM
  #114
jj_008's Avatar
Thanks for the clarification.
Old Dec 21, 2004 | 01:57 PM
  #115
Been on the phone a half dozen times in the last hour working on this stuff.
That is the only new news.
David Buschur
Old Dec 26, 2004 | 07:36 AM
  #116
MalibuJack's Avatar
Yep, I'm being patient.. I'm still trying to find a Beefy enough snap-ring pliers to remove the 2002 (Evo 7 RS2) compressor cover to replace it with a 05 compressor cover so when I send the whole thing to him its already ready for machining and adding of the wheel.. I'm going to have him do the works.... porting, everything possible to the setup before I start taking my car apart... At the moment I'm working on the stroker engine setup and will send out the head around the same time the turbo is turning around.. I should have everything done by the spring.
(just some idle chatter and a bump)
Old Dec 26, 2004 | 11:21 AM
  #117
Zeus's Avatar
I delt with the same issue last week... I bent my usual pliars and had to go to Sears to pick up a set beefy enough to get the job done. They stock two different types that will do the job. The most expensive only being $25.
I can't wait for the turbo either....
Old Dec 26, 2004 | 11:24 AM
  #118
MalibuJack's Avatar
Nice Exactly what I wanted to hear... I'm off to sears hardware now..
Old Dec 26, 2004 | 12:51 PM
  #119
mitsuorder's Avatar
and you might want an extra hand getting those rings in and out while you hold onto the pliers
Old Dec 26, 2004 | 01:04 PM
  #120
MalibuJack's Avatar
Hahah.. Yeah I found that out.. Gotta wait until tomorrow when there's someone around to hold onto this thing..
