p0108
Old Dec 21, 2004 | 09:34 AM
TampaTurbo's Avatar
Question p0108
Has anyone gotten this code before. Some type of Barometric fault code. Like the ECU trying to adjust for elevation or something. It also said something about high input under the (Baro). Would adjusting the rpms on he throttle body cause this to be triggered? Thanks
Old Dec 21, 2004 | 09:44 AM
MalibuJack's Avatar
Your running a UTEC with the V1.7 firmware, its likely you turned the key to start the car before the UTEC had a chance to initialize.. I get that code if I turn the key and immediately try to start the car. The V1.7 firmware apparently takes a little longer to start up than previous.
Old Dec 21, 2004 | 09:48 AM
TampaTurbo's Avatar
OH ok, I ususally start the car after the CEL light discontinues blinking so I know teh UTEC knows what map its on.
Old Dec 21, 2004 | 10:02 AM
MalibuJack's Avatar
Yep, there might have been one occasion where you didn't wait long enough, or for some odd reason the UTEC didn't initialize as quickly.. But I never saw this error until I got the earlier beta's of the new firmware when open loop fueling was introduced, the signal is now regenerated and not just passed through.. Occasionally you might get a MAF error for the same exact reason.
Old Dec 21, 2004 | 10:51 AM
TampaTurbo's Avatar
Do you know if they will have a "fix" for this some time with a future upgrade? I guess I can buy a scanner to remove the codes.
Old Nov 22, 2005 | 12:39 PM
Ultimate CC's Avatar
I am having the same probelm, bump for answers
W_evo8
Jun 16, 2023 11:53 AM
thedru13
Aug 31, 2012 05:55 AM
Evostacio
Dec 12, 2011 10:13 AM
Shaun@AWDMotorsports
Dec 7, 2007 11:00 AM
silver evo8
Aug 9, 2007 09:47 AM
