My 10.5 Hotside Install & How-To
Old Jul 7, 2006 | 10:42 AM
  #256
TURBevO8's Avatar
OK, I've been searching and am getting frustrated here. I see the torque specs for everything on the first page edit of this post, but what about the torque pattern for the bolts? Especially for the manifold? I know there are a lot of people who have done this installation the right way and know where this info can be found. Please help! I plan to do this installation within the next week. Thanks guys!
Old Jul 7, 2006 | 11:05 AM
  #257
MM Racing's Avatar
The manifold is the only thing that I would even consider using a pattern for. Just do it like the cam caps. Start in the middle and work your way to the ends in a circular pattern.
Old Jul 7, 2006 | 11:57 AM
  #258
TURBevO8's Avatar
So there isnt any formal publication that tells you exaclty how to torque the manifold?
Old Jul 7, 2006 | 12:16 PM
  #259
MM Racing's Avatar
There is nothing in the FSM.
Old Jul 7, 2006 | 12:22 PM
  #260
TURBevO8's Avatar
hmm...well I thought there would be. Thanks for the heads up. I just thought there would be since the top and lower bolts have different torque specs. But whatever. If people are just starting at the center and working outward top to bottom with the right torque values then that's what I'll do too. Thanks!
Old Jul 7, 2006 | 01:08 PM
  #261
WarmPepsi's Avatar
i always work up, ie the studs that are 22. i'd start at the center and work out doing 12 ftlbs, then snug them with 18 or so, then final them at the real tq.
Just a habit, kinda do 50%, then 90%, then 100.
Old Jul 10, 2006 | 01:43 PM
  #262
TURBevO8's Avatar
Yeah thats cool. Thats what I do with my lugnuts only this is a bit more sensitive since a seal is involved. But it seems everyone who has done this themselves did this pattern. I am sending my housing to Buschur this week I hope and when it gets back I'm ripping into the car and following this thread (+pulling the radiator). So wish me luck and thanks all for the help!
Old Jul 18, 2006 | 06:11 AM
  #263
dp2580's Avatar
anyone want to help me do this install in the chicago area?
Old Jul 19, 2006 | 01:25 PM
  #264
ibanez_926's Avatar
where at in the chicago area?
Old Jul 19, 2006 | 01:36 PM
  #265
EnJaNir's Avatar
Didn't I tell you I could help in another thread you posted awhile ago? PM or IM me.
Old Jul 20, 2006 | 09:52 AM
  #266
TURBevO8's Avatar
Does anyone have pics of how they switched from studs to bolts between the mani and turbine housing? I've read a lot of people have done this but haven't seen any pics. I'm just curious to see what it looks like and to see what you guys used. Also to see if you used any lock washers or anything like that and if you have the nuts on top of the mani. Just stuff like that. My 10.5 is on its way to Buschur now and when it gets back I want to be 100% ready to tear into my car. Thanks again!
Old Jul 20, 2006 | 10:19 AM
  #267
justchil's Avatar
I'm not sure what you want to see.. you just take out the studs and put bolts in
Old Jul 20, 2006 | 10:28 AM
  #268
RRRS's Avatar
i dont have pics, but there's nothing special to it, just 2 bolts in the front instead of nuts, same as the rear bolts. my hotside did not come with the studs, it's threaded so no need for nuts. sometime people try to back those studs out and end up with stripped threads or snapped studs, so they drill it out to use bolts and nuts. you may want to ask buschur to back those studs out for you, and buy the 2 bolts.
Old Jul 20, 2006 | 10:46 AM
  #269
dp2580's Avatar
any last min. tips on this install before I attemp this on sunday? =)
Old Jul 20, 2006 | 10:59 AM
  #270
justchil's Avatar
Read this whole thread
Don't forget beer!
