Tapping after CAM install
Old Nov 2, 2012 | 04:05 PM
  #181
FpMrIXer's Avatar
very informative thread.
Old Dec 31, 2012 | 06:56 AM
  #182
kevin8086's Avatar
Ok so if you fill with diesel wouldn't that be getting into your oil? I'm still confused about installing empty or with diesel in the lifter
Old Dec 31, 2012 | 11:16 AM
  #183
kaj's Avatar
kaj
the amount is negligible, diesel is very oily, and I did an oil change anyway, once I was done. I figured it was worth the extra $25, just in case, as I had the same concern.
**edit: forgot about this post. I actually ended up not leaving the diesel in; It wouldn't allow me to put the cams in without pushing down on the valves.
Old Oct 15, 2016 | 11:46 PM
  #184
westey2109's Avatar
great info, thanks
Old Oct 17, 2016 | 04:40 PM
  #185
4b11slayer's Avatar
Letting the car idle till the tick goes away shouldnt cause any damage.
Old Oct 17, 2016 | 05:01 PM
  #186
Pal215's Avatar
The 4g63 is an interference engine. Despite what the service manual says, lifters are to be installed empty with all fluids pumped out.
-pal215
justboosted02
76
Oct 2, 2019 04:02 PM
timzcat
130
Feb 21, 2018 02:54 PM
maxroach
Dec 18, 2017 10:07 AM
Howulikemyevo
Nov 21, 2016 07:35 AM
Evogsr14
Apr 20, 2016 09:31 AM
