Installed APS BOV... Almost stalling/Revs drop in 1st gear
Subscribe
Apr 27, 2005 | 03:24 PM
OK. I installed APS BOV a week or so ago and just starting to notice that when in traffic and just starting to move in first gear, RPM drop to almost stalling. This happens when I start to move and then let go of the gas and move to neutral, releasing the cluch, then RPM start to drop below the usual 850-950 to almost stalling and then back up to normal 850-950. Any ideas/suggections????
Reply 0
Apr 27, 2005 | 03:39 PM
do i need to tune it?
Reply 0
Apr 27, 2005 | 03:51 PM
DO you have it hooked up in the right direction? Most aftermarket bov's cause the car to do this. If u have an intake it supposably makes it worse. Most people say they have had the best luck with aps with no idle issues.
Reply 0
Apr 27, 2005 | 03:52 PM
yeah. i got hooked up right and i do not have an intake. i only have the k&n drop in filter. can that be the reason?
Reply 0
Apr 27, 2005 | 03:57 PM
I have never read of anyone having an issue with the APS BOV. Mine is perfect.
Recheck your install, make sure all clamps are tight, the vac source is clean, and leave about a 1/4 of an inch of the adjustment screw out of the BOV, then tighten down the lock nut nice and tight.
Reply 0
Apr 27, 2005 | 04:08 PM
The only time we have heard of this problem happening is when the adjustment nut and screw have become loose and have fallen out. Check those and i bet that is your problem.
Ben
Reply 0
Apr 29, 2005 | 06:47 AM
Quote: The only time we have heard of this problem happening is when the adjustment nut and screw have become loose and have fallen out. Check those and i bet that is your problem.
Ben
Ben, Thanks. I checked the adjustment nut was a little loose. I tightened it and it seem to fix the issue. The car runs better. Also, thanks for hooking me up with the APS BOV and Evo7 tails and fast shippend and great customer service.
Reply 0
Apr 29, 2005 | 06:48 AM
Thanks guys for your help. I really appreciate it.
Reply 0
Apr 29, 2005 | 10:18 AM
Quote: Ben, Thanks. I checked the adjustment nut was a little loose. I tightened it and it seem to fix the issue. The car runs better. Also, thanks for hooking me up with the APS BOV and Evo7 tails and fast shippend and great customer service.
No problem thanks for your order.
Ben
Reply 0
Apr 29, 2005 | 04:41 PM
These APS valves are awesome.
Reply 0
Subscribe
