Last week I installed a Koyo radiator. While I was flushing the radiator I got a CEL thrown. I installed the new Koyo, and the CEL light still remained on. Yesterday I reset my ECU by unplugging the battery for 10 minutes or so. When I turned the car on, the CEL dissapeared. I shut the car off and when I turned it back on about an hour later, the CEL reappeared.
Has anyone had this issue and know the fix for it? I know I should get the code pulled at AutoZone, but the only reason I am asking is because I work 8am-8pm Monday thru Friday and generally our AutoZones close at 8 or so. I will have to leave work early to get the code pulled, so I wanted to see if anyone had any ideas before I took an hour off of work.
Thanks!
Here is my mod list:
GReddy profec B spec II
Koyo Radiator
GReddy boost gauge
Apexi Power Intake
GReddy Type S BOV
Thanks!
Koyo Radiator
GReddy boost gauge
Apexi Power Intake
GReddy Type S BOV
Quote:
I don't know, if you read my post I asked for ideas because it is very hard for me to get out to an AutoZone without skipping some work.Originally Posted by Ev0ikon
what is the secret code?
In any case, I just ran out and I think I solved the problem.
Hows the coolant temp while the motor is running?
Did you add any additives?
Make sure u have all electrical connections plugged in snug.
maybe u have a air pocket in the water jacket or something.
Ur best bet is to get the code read and go from there.
