Throwout bearing problem
Old May 11, 2005, 01:21 PM
j-evo8's Avatar
I was getting a howling noise when the clutch was halfway out on a downshift or when starting the car from a stop.
When the tech at the dealership sprayed some lubricant on the throwout bearing, the noise stop and goes away for a while until the lubricant wears off, then the noise comes back.
Any suggestions or help on this? I know the throwout bearing might not be seated correctly, but this happend on the stock clutch at 2000 miles and continued from day 1 after I had my exedy twin disc and new OEM TB but in at 5000 miles. I now have 8k on the car. Any suggestions? Thanks in advance.
Old May 11, 2005, 01:59 PM
03BREvo8's Avatar
its probably getting wet in there.. mine did it .. but after a week it went away.. i also have a new clutch , tb, and flywheel.. so make sure the tranny vents are backwards ... and just let it dry out
Old May 11, 2005, 02:02 PM
j-evo8's Avatar
this is happening for the last 6000 miles. TB has been replaced and so has the clutch. Car is garage kept, doesnt matter the weather. Thanks for the info though. Anything else?
Old May 11, 2005, 02:04 PM
03BREvo8's Avatar
well it could also be bad.. they may have warped it putting it in .. is it a stock tb
Old May 11, 2005, 02:05 PM
j-evo8's Avatar
Brand new OEM TB when they changed the clutch.
Also had hte same noise with the TB straight off the lot from 2k - 5k (when the new clutch went in)
Old May 11, 2005, 05:54 PM
03BREvo8's Avatar
well at idle it whines? what about cruising around?
Old May 16, 2005, 10:24 AM
j-evo8's Avatar
No whine at idle. Only makes any kind of noise when downshifting as Im letting off the clutch.
Old May 30, 2005, 02:40 PM
Thegame's Avatar
Mine did the same thing today; only when downshifting and it has been raining here quite a bit, so I'm assuming I got water in there. So I'm okay then right? It did this only one other time in the rain, and it never does it in the sun. I hate PA weather by the way.
Old May 30, 2005, 02:45 PM
racerhead2's Avatar
Get it replaced again if you are annoyed by it. But usually the noise is o.k. It won't break your car. Until you start seeing bearings coming out falling on the ground! lol
Old May 30, 2005, 02:47 PM
yesevo's Avatar
not installed properly... or the snap ring that holds TB came off ,loose .or bent.(it happened to me).
captinnitro
Feb 24, 2016 10:03 AM
Kealinstillz
Mar 18, 2015 07:11 PM
evilempire76
Jun 12, 2007 01:14 PM
AzNeVo8
Jul 5, 2005 08:18 PM
MitsuJoe
Apr 5, 2005 01:01 PM
Quick Reply: Throwout bearing problem
