Defi Bf Oil Pressure Gauge Questions
Originally Posted by lilman8403
i'm sorry man, i found it on evomoto.com but it was boost and egt install,try this https://www.evolutionm.net/forums/sh...l+temp+install
didn't mean to confuse you.
good luck
good luck
You need an adaptor that is 3/8 PT MALE to 1/8 PT FEMALE. The Defi BF's are most definitely PT. Brass is fine since the pressure is relatively low.
and PT = BSPT
You can install the sender without draining oil, only a small amount will pour out.
and PT = BSPT
where did you guys buy the 3/8 PT MALE to 1/8 PT FEMALE reducer? i had friends in the states try home depot and loewe's with no luck, but since i'm stationed in germany i can't get anything locally. no luck with online stores, either...
thanks, actually i just finished the install. i ordered the 3/8" to 1/8" adapter for the oil temp gauge from 42DD and used the bung by the oil filter, then i replaced the factory oil pressure sensor with the defi one since it's already 1/8" PT.
for people that replace the factory oil pressure sensor, make sure you have a long 1" wrench to take the factory sensor off. i had to remove the battery, front strut bar, and upper IC pipe to get at it.
also, it wasn't mentioned here, but i've hear of potholes ripping the oil filter assembly off after people lowered it by using the greddy adaptor... that's why i didn't go that route.
Sam@DriveLine
EvoX 'For Sale' Electronics / Lighting / Audio
121
Jan 8, 2009 02:20 PM
Blacksheepdj
Lancer How Tos / Installations
Apr 21, 2006 09:39 AM
