New Bolt in turbo... FP White Rabbit.
Old Jun 16, 2005 | 06:08 PM
  #331
Zeus's Avatar
Again, as much as I love them to move product... I've been informed that there will not likely be any group buys...
Old Jun 16, 2005 | 06:10 PM
  #332
EVOeight's Avatar
Maybe this new White Rabbit turbo is a MR turbo but with the 6.5 TME titanium turbine/shaft assembly. That would give it the larger compressor housing and blade as well as the 10.5 exhaust housing with the revised wastegate flapper but would have the lightweight rotating assembly. The best of both worlds…
Old Jun 16, 2005 | 06:16 PM
  #333
Zeus's Avatar
The compressor is a FP design that has been in the works since 2003 if I remember right... the wheel that is...
Old Jun 16, 2005 | 06:23 PM
  #334
nickracer9's Avatar
i wonder how this comp wheel would work with the 06 comp housing!
Old Jun 16, 2005 | 07:00 PM
  #335
Ludikraut's Avatar
Zeus,
I guess my question got lost in the hullabaloo here ... so to reiterate:
Do you, or FP, know at what efficiency plateau (%) the WR moves the 700 cfm you alluded to?
l8r)
Old Jun 16, 2005 | 07:13 PM
  #336
Zeus's Avatar
Sorry, I didn't ask where, I just simply asked what it would move... I'll be more specific with the man when I get the chance.
Old Jun 16, 2005 | 07:28 PM
  #337
TD05HR's Avatar
PF... you guys have compressor map for this turbo..? EMS numbers is awsome. ..but i would like to see it on flash like alot of ppl on here...
Old Jun 16, 2005 | 07:29 PM
  #338
Evol_VIII's Avatar
Are we sure on the 700CFM #. I mean that is in the 50lb/min range depending on what you are using for caculations. That is a lot of air to be moving. Can we get some data from FP on the specifics of the compressor flow and the efficiency?
Old Jun 16, 2005 | 08:45 PM
  #339
1.8t's Avatar
Stock is 550cfm correct?
Old Jun 16, 2005 | 09:01 PM
  #340
Zeus's Avatar
Absolutely on the 700cfm... directly from Robert.
Old Jun 16, 2005 | 09:17 PM
  #341
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I'm not sure you will get this information. I've tried to from a few other vendors on here and have not been successful.
Old Jun 16, 2005 | 09:25 PM
  #342
marksae's Avatar
Wow, that's pretty close to the FP Green, which is rated for 730 CFM. How is the transient boost response of this turbo?
Old Jun 16, 2005 | 09:50 PM
  #343
evo_dadi's Avatar
hmm so i guess with this new toy im gonna need a new clutch now since im pretty much covered with the rest of the bolt ons i think imma have to give them a call tomorrow now
Old Jun 16, 2005 | 10:19 PM
  #344
sandm's Avatar
subscribe
Old Jun 17, 2005 | 04:44 AM
  #345
Tym Switzer's Avatar
For those of you interested, there is another available option to upgrading your stock turbo on your Evo using the compressor side components of the rabbit.
If you have an 03/04 with the standard steel turbine/9.8 housing, it can be upgraded with the compressor side of the rabbit. The cost of the upgrade will be $895.00. If you already have the TME with the ti turbine wheel/10.5 housing, then you can also upgrade the compressor side and have the Rabbit, again, for $895.00. The smaller 9.8 a/r housing will spool a little quicker, however, the steel turbine wheel will more than likely negate that benefit.
Robert is currently upgrading a couple of stock turbos (stock 9.8 and TME) for us to offer on an exchange basis for customers who would like to upgrade here at the shop. As long as the car drives in on a good core, it can drive out on an upgrade. We also have the dyno available for evaluation of the work performed should anyone choose.
I think this is a more cost effective option for most.
Take care,
