blown engine will it run the same
Old Jun 22, 2005 | 10:14 PM
EvOJoHnY0312's Avatar
ok i recently blew the engine and it was covered by the warranty but i was also wondering will it run the same or will it run better,worse do i have to break it back in need info thanks guys
Old Jun 22, 2005 | 10:21 PM
savageevo's Avatar
can you give some detail how you blew it up.
Old Jun 22, 2005 | 10:23 PM
jeffm1999's Avatar
Yes you will have to break it back in becuase you need to mate the pistons and rings with the inside cylinder walls. It may feel like it runs better to you because you will have brand new compression values, assuming there is nothing else wrong with your engine. Just out of curiosity what happened? Melt a piston, turbo throw a blade? Any other parts/systems damaged?
Old Jun 22, 2005 | 10:41 PM
well i work for a mortgage company i would travel alot out of state soo i left to florida for six months and during the time i was over my cousin took my car and never changed the oil so came back happy to see my car and wanted to drive it well like to days later i hear a knocking noise, i blew a rod cause he put over 6,500 miles with same oil didn't know it was basically oil starvation and i still got the warranty on it
Old Jun 23, 2005 | 06:08 AM
buggy's Avatar
I'll bite..
That's not the cause--6500 miles on oil, no biggie.. you either had a defect from the factory, low oil level, or your cousin was beating the living sh%^ out of your car.
buggy
oops just read your last post again.. yes i would say oil starvation.. i'll shut up now.
Old Jun 23, 2005 | 06:23 AM
DCSilvrEvo's Avatar
damn!!!!!!!!!!!!!! I CHANGE MY OIL EVERY 5g But i tend to chill when my oil is LOW or OLD!
Old Jun 23, 2005 | 06:24 AM
Compjoc's Avatar
I hear many horror stories from ppl letting friends drive their evos and breaking them.
It should drive the same if the dealerhsip knows what they are doing.
Old Jun 23, 2005 | 06:30 AM
VTECH8TR's Avatar
I'll give you a bit of advice DON'T LET YOUR FRIENDS DRIVE YOUR CAR, this happened to me and well i had to fix it myself. I learned the hard way 2. Except my car is soo moded that i fixed it myself.
Old Jun 23, 2005 | 06:39 AM
wheming's Avatar
You are lucky they actually covered this under warranty, since it was an operator responsible failure.
I don't like anyone to drive my vehicles either. I would rather they sit. If they do need to be driven and you can't trust them, remove the arm from the wastegate actuator. That way, at least they won't be able to build any boost.
NaughtyEvo
11
Apr 12, 2020 07:16 PM
elim0
Jun 16, 2015 05:40 AM
jdm phil
28
Jan 28, 2012 09:54 AM
dadsgts
Apr 11, 2011 09:50 AM
