Where can I get fuel injector o-ring other then dealer?
Old Jun 25, 2005, 11:01 PM
USP45's Avatar
I have just dropped my 2.3 block in and I noticed that the upper fuel injector o-rings where they go into the rail have dried out from not being in the manifold while the short block was being done. I know that the dealer sells the upper o-ring, but at $15 for 4 of them I think that the price is outrageous, especially as I need 8 of them for the Delphi injectors at 2 per injector. Does anyone know of another car that uses the same size o-ring on the top of the injectors? Auto parts places stores sell o-rings, but they come in all sorts of different sizes.
Old Jun 26, 2005, 06:51 AM
DSMotorsport's Avatar
we stock them
Old Jun 26, 2005, 07:55 AM
GTVEVO's Avatar
I have seen people pick them up at a local autoparts store just by matching up the thickness and size of orings they have.
Old Jun 26, 2005, 09:09 AM
Z1 Performance's Avatar
yep - most every autoparts store should stock them...even Home Depot, etc..its just an o ring
Old Jun 26, 2005, 10:31 AM
USP45's Avatar
Just in case anyone else needs them, #78 o-rings fit great, you can get 10 of them a Lowe's for $1.27. Thats a little bit better the the stealerships price of $15 for 4 of them.
Old May 6, 2007, 12:03 PM
justchil's Avatar
I just picked up a set of these from Lowes (located in the plumbing dept). I'm wondering how they hold up over time having direct contact with fuel??
Old May 6, 2007, 10:26 PM
MrEvo2U's Avatar
They are not 'just' o-rings. They are a special substance that is impervious to fuel. Auto parts stores sell them if you can match the size. You really don't want to use generic o-rings and have fuel spraying on your hot engine.......
Old May 7, 2007, 07:13 AM
tkklemann's Avatar
Yes, there are actually two types of O-Rings, Bunna-n and Viton (SP?)
The Viton (SP?) O-Rings are prefferable because they are less prone to dry-rot cracking from contact with liquids such as gasoline.
Old May 8, 2007, 11:43 AM
Steve_P's Avatar
you're on the right track, but there are at least 6 different o-ring materials.
Old May 8, 2007, 03:27 PM
sonicnofadz's Avatar
+1 Do NOT just buy a generic o-ring! Gasoline will eat through it and you will have major fuel problems and a possible dangerous LEAN condition!
Xearo
Sep 15, 2012 10:33 AM
EvODavO
Jul 30, 2012 07:50 PM
Huntington MR06
Mar 24, 2011 12:07 PM
vegasse
Aug 27, 2009 07:57 PM
eponti
Sep 7, 2007 10:09 PM
Quick Reply: Where can I get fuel injector o-ring other then dealer?
