1st gen eclipse
Old Jul 14, 2005 | 12:16 PM
F&I-EVO's Avatar
1st gen eclipse
I know this is off topic but i trust Evo guys knowledge.
My friend bought a 1st generation eclipse (4g63)for 1g. It does not start (it cranks and turns over). He is a mechanic so we know its getting fuel and NOT spark. Do you guys know what it could be?
Old Jul 14, 2005 | 12:19 PM
evo 8 ya's Avatar
It could be a bad MFI relay, coil pack or a toasted ECU I've seen all three before.
Old Jul 14, 2005 | 12:20 PM
DsmAwdTurbo's Avatar
I second that
Old Jul 14, 2005 | 12:21 PM
F&I-EVO's Avatar
thanks guys!
Old Jul 14, 2005 | 12:24 PM
F&I-EVO's Avatar
The previous owner said that the car stop working after he removed the radio. Could this mean something?
Old Jul 14, 2005 | 01:22 PM
evo 8 ya's Avatar
Maybe but, Probably not
Old Jul 14, 2005 | 02:34 PM
Jrod@Buschur's Avatar
It sounds like an ECU to me as well. My '92 did that. It would crank and crank and crank but wouldnt turn over. Tried to get it started with some starting fluid and still nothing. Threw another ECU in it and she fired right up.
Jarrod
Buschur Racing Inc.
Old Jul 14, 2005 | 02:41 PM
thebluesky's Avatar
ecu or coil pack. chances are it's the ecu, but check all your connections to your coil pack. I had a similar problem when to plug worked itself loose and subsequently fell off.
Old Jul 14, 2005 | 05:30 PM
timzcat's Avatar
get a wiring diagram and see if the ecu is sending the voltage out the wire that goes to the power transistor. This is usually the cap issue in the ecu.
Old Jul 14, 2005 | 05:36 PM
evo 8 ya's Avatar
I have a spare 1G ecu that works, if you need one.
Old Jul 14, 2005 | 08:15 PM
SAEID's Avatar
ROFL... Everytime I washed my 2g, something would always break.
Old Jul 15, 2005 | 12:44 AM
marksae's Avatar
Check the fuses! Can't hurt anything to check. It could be a real simple solution.
B00std4g63
Aug 13, 2012 06:49 AM
1GHAAAAAW
Northwest Region
141
Jun 11, 2008 11:53 PM
1st_Gen
Jan 23, 2008 09:37 AM
Lancer2See
Lancer Engine Tech
Apr 17, 2003 09:43 AM
