Prototype Bolt-On Turbo Testing
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by Soon2BEVO
$280 for a wastegate actuator godddddddddamnnnnnnnn!
Does it work? Holding 22psi to redline?
Originally Posted by robertrinaustin
The Buschur is about $100 less and holds high boost.
Originally Posted by rlazer5000
Does Buschur have this item on their website? http://www.logicperformance.com/data...roducts_id=893 is this the same item that Buschur is selling? Thanks man!
Buschur sales both the Forge (looks the same as your link) and their own upgraded actuator. I'm not sure if either are on the website, but you can call Jarrod at (440) 839-1900 and he will take care of you
The Buschur is about $100 less and holds high boost. They also have the Forge.
Originally Posted by mitsuorder
So which is it? Buschur is using the Forge from what I have heard.
Need anything else, I'm sure the guys at Buschur can help you out.
Update: Got the ACT installed yesterday and still waiting on the Forge upgraded actuatur spring. Hopefully, we'll get that in and get the car to the track on Wednesday. I'll also post some graphs this weekend from a dyno day held at MZM last weekend to give you some comparisons.
Here are some dyno sheets from the 7/30 Dyno Day at MZM. I've included my sheet from the day before when my clutch started to let go. The new clutch is in and feels great and hopefully the new spring for the actuator will be in this week so that I can run a high boost race map.
EVO and STi Dyno Sheets - Dyno Day 07-30-2005.doc , please right click and save.
BTW, check out the 03 WRX in the link above. It has an STi Spec C motor with the basic bolt-ons and an APS DR65. It made 440 whp (70 more whp than a GT35R EVO at similar boost) at 28 psi on race gas. Compare that to all the other numbers and you'll see the WRX was KING!
Nice numbers on the WR, although it's still falling off quite a bit up top. Can you overlay your WR run with an earlier non-WR run on your car?
The RNR GT35R looks like it is teh suxors.
l8r)
l8r)
Your car pulled very well all of the way up, pretty impressive. Who is doing the tuning on your's and Tony's maps? It looks like Tony's map could be cleaned up some if the smoothing feature was set similarly for both.... Not too bad though, and you said that this is a low reading dyno?
l8r)
l8r)
Stock 03s are about 185 whp and 05s are about 195 whp to give you an idea. Mohammad's car ran an 11.6 1/4 when he dynoed 336 whp on this dyno.
I should have track numbers later this week. I got my upgraded actuator spring in today and will get it installed this week. Special thanks to Forge and Buschur for helping me figure out and solve the problem.
Ludikraut, My car has the SS55 prototype turbo, not a WR. I can overlay my pull with a similar stock turbo car if that is what your asking.
Yes, I'd be interested in a stock turbo overlay.
l8r)
I was asked to run a prototype turbo, the SS55 on my 03’. The turbo is based on an 05’ MR 16G and has larger compressor wheel.
