Nisei FMIC
Old Jul 27, 2005 | 10:59 PM
Str8Ryda's Avatar
Originally Posted by LordEvoIX
Your AEM logs showed engine temp via water or oil temp readings? If water temp reading, at what speed was the car travelling when the reading was taken? Just wanna make sure that the dense fins count isn't a big issue when the car is at speed. I'm thinking that even if there's a water temp raise of 5C to 10C, I can live with that If I'm not wrong, the extra power generated through the denser intake air should also generate more heat thus raising the water temp. It's all interconnected right?
We need more reviews from unbiased users...the vendors war is fudging the facts up badly
LordEvo,
https://www.evolutionm.net/forums/sh...4&postcount=21
and if you want more info check this one out.
https://www.evolutionm.net/forums/sh...3&postcount=50
Cheers!
Old Jul 27, 2005 | 11:28 PM
LordEvoIX's Avatar
Originally Posted by Str8Ryda
OMG...the 2nd link is simply killer
Old Jul 28, 2005 | 02:29 AM
trinydex's Avatar
there is no problem with the radiator air flow. the nisei is a giant and it is the best performing piece on the market today.
Old Jul 28, 2005 | 10:01 AM
Ted B's Avatar
Originally Posted by nickracer9
i have it and it's a great i/c. my intake temps dropped around 20 degrees. it was a noticeable gain. intake temps always match ambient temps, and as i boost the temps get cooler. thats my experience.
Having inspected all the popular ICs, I chose the Nisei unit because there is little doubt in my mind that the it is the most efficient IC presently available for the EVO at any price. I'm not observing any increase in engine coolant temp, just considerable power and cooler intake temps. To put things in perspective however, I'm not convinced the actual differences between the most popular ICs make that much of a difference in a real world setting. As far as power numbers, we're probably talking peanuts.
Old Jul 28, 2005 | 11:47 AM
Creamo3's Avatar
I have it and love it, I noticed some power gain but nothing too astonishing for my level of mods. The construction, quality, and finish are top notch, more than I can say for some other FMIC's on the market , plus the looks are worth the price of admission.
Old Jul 28, 2005 | 06:07 PM
LordEvoIX's Avatar
Any unhappy users of Nisei here? So far, we only have glowing reviews from users and a few negative ones from non-users and competing vendors. I will be going with Nisei in that case since its pretty clear who I shld be listening to
Old Jul 28, 2005 | 06:36 PM
nickracer9's Avatar
you won't be dissapointed!!!!!
Old Jul 28, 2005 | 06:37 PM
Widebandphillip's Avatar
does the nisei fit the stock intercooler pipings?
Old Jul 28, 2005 | 06:39 PM
LordEvoIX's Avatar
It is a direct replacement for the stock intercooler, mounting up to the stock pipings. I'm talking abt Evo8 here.
Old Jul 28, 2005 | 06:47 PM
Erik@MIL.SPEC's Avatar
I love my Nisei. In fairness, I would say the AMS is a great piece too. Shiv likes it better because the turbolaters (sp?) are shorter
Old Jul 28, 2005 | 09:25 PM
DUROEVO's Avatar
The Nisei is my next mod.....waiting for the piping to be comleted.....if you have any "?'s" on any intercooler or want to know about intercoolers you can contact Rob at myevostore.com or even Nisei enginering.....They have loads of info for anyone...
Old Jul 28, 2005 | 10:06 PM
Jaylenospoolboy's Avatar
The only downside I see is it is 12 lbs heavier than stock and is mounted way in front of the front axle. The rear end feels a bit lighter under hard cornering.
That being said, all of the other aftermarket intercoolers, if they are any good, should be heavier too I would think.
I guess this is why Nisei is offering the mini battery. You get back to where you were at stock.
I think it looks like the evo X
Attached Thumbnails Nisei FMIC-mitsubishi-20lancer-20evolution-20ix-20-201024x768.jpeg
Old Jul 28, 2005 | 10:30 PM
Derek888's Avatar
How heavy is the stock intercooler? I have the Greddy Rspl and it weighs 12 pounds when I put it on a scale. If you are correct on the Nisei's weight, then their IC is not light. I paid 820 for the Greddy Rspl which comes with the lower pipes which I think is a good deal.
Old Jul 28, 2005 | 10:35 PM
The Nisei is heavy. Heck, it's a 3.5 inch core
Old Jul 28, 2005 | 10:43 PM
LordEvoIX's Avatar
I don't think weight should be a consideration in choosing an intercooler meant for the streets. The light intercoolers tend to be of the tube and fin variety and one of their downsides is that they lack the thermal mass to absorb heat when the car is not at speed and airflow minimal. That's why they get heatsoaked easily and if your car is primarily street driven, I think the bar and plate variety is more useful. I was told that the Japanese manufacturers prefer tube and fin intercoolers because being designed for racing where the car is continually at high speed, less pressure drop and weight savings are more important. We must also know that tube and fin intercoolers are generally cheaper too. Interesting to note that the highend HKS and ARC intercoolers are of the bar and plate design.
