White Rabbit Real Deal 415awhp
Old Aug 5, 2005 | 12:38 AM
  #151
Ted B's Avatar
Originally Posted by fury656
This setup much like tuning the stock turbo to its absolutes is more involving then simply throwing on a big turbo setup which will make numbers regardless of whether or not a setup is properly matched to best take advantage of it.
The turbo is matched to the static mechanical efficiency of the engine (not the other way around), which is partly determined by the cams. If a cam set that is proven to increase mechanical efficiency in every other application suddenly appears to falter, I'm afraid that it would require a fair amount of investigation to convince me that the turbo blocked the expected increase, unless of course it had some unusual physical attribute, and I'm not convinced that's the case.
Old Aug 5, 2005 | 08:01 AM
  #152
3000ways's Avatar
Originally Posted by Evo2Envy
EDITED after reading a little bit more ... but still, there's no way a 325-340hp evo could keep up with a 580hp mercialago(spell check)...
I don't know what this has to do with the White Rabbit turbo but since we are off topic, your right in the straights, the Lambo is gonna pull hard on the EVO, but I don't see how it would be impossible for the EVO to keep up on a tight handling course, the EVO is an incredible road course car, the Lambo is very good too, but the FQ400 is pretty much made for that type of racing. I mean AWD, plus weight that hovers around 3000 to 3100Lbs (Lambo weighs in close to 3600Lbs), plus incredible suspension, and shorter gears makes the FQ400 an awesome car on a tight road course. Again on the straights the difference in HP will be evident and the Lambo should pull pretty easily.
Old Aug 5, 2005 | 08:25 AM
  #153
954DRGSR's Avatar
Exactly we need to get back on Topic.
