White Rabbit Real Deal 415awhp
Old Aug 3, 2005 | 11:27 PM
  #106
plokivos's Avatar
BR Stage 4 with 272s
Shell 93 with Meth
27lbs
ecu flash.
this would break into 400 whp with stock turbo, stock manifold.
but torque would be a little shy of 400.
but really if you do compare the consistancy of the dyno tuning on that, it looks very straight from the peak whp and torque.
they look very good.
it'll definitely be a lot quicker than peaking whp evo with that setup on stock turbo.
ran the 1/4 yet?
Old Aug 4, 2005 | 12:18 AM
  #107
mike 99gsx's Avatar
Originally Posted by statix
Ouch, those facts are hard to pass.
A stock turbo with alky and ems with supporting mods would also make around 400hp, I dont see the benefit, keep in mind, an alky equiped evo would have a longer torque curve also.
Find me a dyno sheet of a stock turbo car that makes this much power on pump and methanol at 7500RPM (read not a stupid boost spike!!!). If you find one, then I will declare Al the everlasting know it all
Old Aug 4, 2005 | 12:20 AM
  #108
SubiEvolved's Avatar
dyno numbers mean nothing. when will people learn..........
Old Aug 4, 2005 | 12:43 AM
  #109
evo8chris's Avatar
hahaha. its on how you drive it huh =P
Old Aug 4, 2005 | 04:19 AM
  #110
DynoFlash's Avatar
This is most true which is kind of why I repsect the way that Buschur markets its products - with drag times and carful disclosure of testing conditions
Old Aug 4, 2005 | 05:03 AM
  #111
GOKOU's Avatar
Originally Posted by DynoFlash
Actually - I can make more power with Methanol and pump gas than on race gas due to the intercoolling effect of the methanol it cools the charge dramatically which is a huge benefit especially when you have 100 degree ambient temps.
I'm looking forward to this magic . Adding alky kit very soon on BRS4 272/272s with stock 03 turbo so it should be a good comparison (in some way) to this one here. I don't have AEM and don't have WR but I"m sure the $$$ I save is
Old Aug 4, 2005 | 05:13 AM
  #112
4G63>OOOO's Avatar
To clarify - I agree that the WR is a great unit and that it represents a nice value.
My only beef was with the original 441 whp dyno claim on a car without cams. Now that I see the same tuner making less whp with more mods it just re-enforces my original assumptions.
The 441 run is what it is. 120 octane, $20.00/gallon leaded race fuel on a car with basic boltons.
The 415 run is what it is. 93 octane with methanol injection on a car with more than your basic bolton, meant to be driven every day.
Didn't you say yourself a few months ago that you could make more power on VP120 than you could on C-16, on average 30WHP without changing a thing in the tune?
I think this is another case of apples to apricots.
Old Aug 4, 2005 | 07:46 AM
  #113
Zeus's Avatar
Originally Posted by GOKOU
Good numbers! Don't want to end up with a pissing game again but I don't know if this shows anything signifant about the WR unless you show what your prior numbers were. I've seen similar numbers with the stock turbo and meth. I like the WR but ????. To each their own.
https://www.evolutionm.net/forums/sh...d.php?t=151505
I don't know why this graph is applicable to this discussion other that the "peak" numbers ... in this graph you are clearly "stepping off the freight train" at 5500rpm compared to black evil evo's. The OE turbo in this graph would obviously have it's *** handed to it side by side, two drivers being even close to equal. Of course again this is an apples to grapefruit comparison anyway.
Old Aug 4, 2005 | 07:54 AM
  #114
GOKOU's Avatar
I think you and amny other must have taken it the wrong way The idea was to point out that similar peak numbers can be achieve with stock turbo. Obviously we all know the WR is better then the stock turbo and it better be. For the extra $1550 and $1400-$2500 money he better win or
Old Aug 4, 2005 | 07:59 AM
  #115
MalibuJack's Avatar
Its funny you mention that, I actually noticed the same thing..
Old Aug 4, 2005 | 08:21 AM
  #116
Fenris Ulf's Avatar
Sorry, but I sincerely doubt throwing in some 120 without changing the tune will pick up 30 magical awhp.
Who gives a flying $%@# what the WR dynos? Not me, not on a forum where people post dynos daily from a half dozen different machines with a half dozen different correction factors and are IGNORANT enough to compare the sheets!
Take it to the track, it should easily best the stock turbo.
  #117
4G63>OOOO's Avatar
So we know that methanol+ pump gas is a great combination, but can you be as aggressive with that as, say, a full tank of VP Import 120?
Old Aug 4, 2005 | 08:22 AM
  #118
Fenris Ulf's Avatar
He just said you could be MORE aggressive...
Old Aug 4, 2005 | 08:43 AM
  #119
evoviiiyou's Avatar
Is it possible that the stock cams work better with the WR than 272, and 280's? This is the conclusion that I get.
Old Aug 4, 2005 | 08:45 AM
  #120
Zeus's Avatar
Trust me, I'm not really worried about proving the unit like many are. I drive the proof around every day (well I did before the Evo just became a weekend car). Matter of fact, if this unit made the exact same power as a stocker across the board, but kept all the other drivability attributes, transient response, low rpm surge reduction, etc, I might still think it an ok buy for the avid daily driven/weekend road course car. However, no one seems to want to concentrate on the "icing".
