White Rabbit Real Deal 415awhp
Originally Posted by Rez90
honestly...i will have to disagree a little bit with that statement.
The first two cars to recieve turbotrix's turbo upgrade (which is a modded 50 trim) made 430 and 450 on pump gas...no alky, no nitrous. just 22psi of boost.
i know this cause my 03 was one of them
it was stellar to me and everyone who rode in my car
Originally Posted by Event-Horizon
I'm not a hater, but I would much rather see results without an aid such as meth or alky before someone comes on and says "to all the haters". I think that it would tell more about the turbo and how it compares to cars with BR stage 4 or Vishnu Stage 1+. People then might take it more seriously.
https://www.evolutionm.net/forums/sh...8&postcount=68
Lets look at what this turbo is:
- An upgrade to stock, that sacrifices very little spool
- Torque and HP gains are nominal, but its area under the curve are extended significantly
- Bolt-on swap (With or without BPU mods to take advantage of it)
- Cost effective compared to other options
- Good performer on alky
- Stealthy (probably would even fool a dealer mechanic)
- As drivable as stock
You make very little sacrifices to make gains, whether their 20hp or 100hp, thats not important, but the car feels better and is more fun to drive.
Personally, I would hate to watch the clock waiting for a turbo to spool, for me, if I went with an aftermarket turbo upgrade (Complete kit) It would be a 3071 or a 3076 and a 2.3/2.4 stroker engine.. This would likely feel pretty good to me. But its WAY more expensive than an $800/$1500 upgrade..
And I wouldn't be surprised to see one of these "Properly tuned" and properly driven cars crack a 10 second quarter.. You see all these big turbo guys talk about their dyno numbers, but very few are posting 10 second timesheets..
Perspective guys... Perspective.... What good is a giant shlong if its flaccid until the deed is almost done?
If you look at Turbotrix "case study" you will see a stock 03 turbo about the some mods less aem put down about the some hp #'s . But the WR holds 400hp for 2000rpms and the stocker holds 400hp for 500 rpms and it lost 20hp at redline .
How much do you think 15-20 hp from 5500-7500rpms is worth in trap speed ? 1-2 mph or less ?
and that power difference is probably worth 1-2mph in the traps.
l8r)
If you're looking for BIG power numbers, this turbo is not a budget GT35R...not even close.
One doesn't have to look further than the specs and basic dyno numbers to conclude that the WR should not be expected to give a significant peak power increase above what is capable with the stock unit. What it will do is keep the power curve going a little longer than the stock unit without compromising low power driveability. The peak numbers in the original post can be matched with the stock turbo and no standalone. The difference is in the average power, not peak. If you can read a dyno chart, you can see this. Unfortunately, half the people who post here can't even spell correctly, much less properly interpret a dyno chart.
For the sake of comparison, there's no reason to make it any more complicated than that.
But really, you can't accurately quantify the average power gains without a back to back comparo of the stocker to the WR. Yes it looks like the power curve is much more flat, but I think the doubters just want a reasonable quantifiable figure.
why is this always about power? if you want higher power numbers why don't you take off the intake and dyno on a colder day? but is that meaningful? not really... was it a mistake to publish numbers like that on the wr? probably...
this turbo isn't about power... it's about response, boost up, holding boost to redline and making very quick laptimes and by laptimes i mean laps ARound a track... not down the track.
