installed my XSPower intercooler this week
Old Feb 24, 2007 | 03:34 PM
  #211
honda-guy's Avatar
Originally Posted by DrivenToThrill
Whoa Whoa Whoa wait a minute......how in the H E Doulbe hockey sticks did you get this piece of crap to fit I have spent over 3 months trying to fit this fitment......and its still not centered, couplers still do not match up without kinking up, and the bumper doesn't go on nicely. I have fought this for to long......now you must help me LOL.......
By the way I am from York, PA 17402 Whats Up!!
which top bracket did you use? mine came with 2 different top bracket. one that is straight and one that is offset. i used the offset since the mounting point on the IC is center and the bolt on the car is off centered. maybe your IC pipes aren't lined up correctly. i think it only took me about 2 hours to do mine and the hardest part is getting the hose on the IC. you can heat the hose up a little so it can bend easier but it should not kink at all. you should only have to straighten the hose maybe 5 degree from the original angle. the bumper fit nicely, but i didn have to cut the under tray (look at the pices on the first page).
i'm from Carlisle. stop by and i can help you.
Old Feb 24, 2007 | 08:16 PM
  #212
DrivenToThrill's Avatar
no I mean I used to live in York, I have fam there
Old Feb 24, 2007 | 09:17 PM
  #213
honda-guy's Avatar
ahh, i didn't even look at you current location under your avitar.
Old Feb 26, 2007 | 09:58 AM
  #214
honda-guy's Avatar
after reading Buschur's post about cleaning the inside of the IC, i decided to do mine and got a chance to take some more pics. when i did the original post, i didn't know there was going to be a much headed debate about this IC, so here are some more pics to clear up some misconceptions.
i also weight the IC and it turned out to be 22 lbs with the backets on.
the front view
driver side hose
passenger side hose. notice that on both side, the hose have to be straighten a little. this is where most people have the problem. but notice there are no kinks in the hose.
top bracket
bottom bracket
the welds, not bad for a 12 years old kid, huh. not a perfect roll of coins but good enough to keep the boost in.
outside cooling fins
inside cooling fins
another shot of the inside cooling fins. some of the inside fins are bent because i was using compressed air to dry out the IC after i cleaned it.
Attached Thumbnails installed my XSPower intercooler this week-1.jpg   installed my XSPower intercooler this week-2.jpg   installed my XSPower intercooler this week-3.jpg   installed my XSPower intercooler this week-4.jpg   installed my XSPower intercooler this week-5.jpg
  #215
honda-guy's Avatar
more pics.
Attached Thumbnails installed my XSPower intercooler this week-6.jpg   installed my XSPower intercooler this week-7.jpg   installed my XSPower intercooler this week-8.jpg   installed my XSPower intercooler this week-9.jpg
Old Feb 26, 2007 | 10:03 AM
  #216
dudical26's Avatar
Do you have a link to the upper IC pipe.
How would you say it fits?
Old Feb 26, 2007 | 10:06 AM
  #217
mitsuorder's Avatar
we need to start a donation fund to get honda-guy a set of jackstands before we see him as a headline story on the news.
Old Feb 26, 2007 | 10:08 AM
  #218
whitersevo's Avatar
^^^^^ wow that isnt very safe.
Old Feb 26, 2007 | 10:09 AM
  #219
honda-guy's Avatar
i have Injen upper IC pipes. the lower pipes is XSP and it came with the the IC when i purchased it.
Old Feb 26, 2007 | 10:14 AM
  #220
honda-guy's Avatar
hey, i could aways use a donation.
all jokes aside, i do have two jack stand under the car, each next to the jack on each side (you just can't see it in the pics). the front jack is holding up the engine since the tranny is. i try to be very cautious when working under the car or when the engine is running. i witness my friend lost a finger when the glove got pulled in by the timing belt and crushed his fingers. i had to drive him to the hospital.
edit: you can see part of the jack stand leg on the first pics next to the passenger side jack. oh, and the rear wheels are on ramps with the ebrake on.
Old Feb 26, 2007 | 11:37 AM
  #221
My problem is with the connecting ports of the IC and the bottom brackets, I dont even have the bottom brackets bolted down they wont reach. Also The LICP JUST fits, I have the couplers extended as much as posible. I will take pics for you guys if you want........I will do that tonight.
Old Feb 26, 2007 | 11:45 AM
  #222
honda-guy's Avatar
i monted the bottom brackets first, then i had to bend the top bracket a little so it would line up with the bolt.
Old Feb 26, 2007 | 12:02 PM
  #223
O I see LOl good idea ....lol
Old Feb 26, 2007 | 12:03 PM
  #224
Im getting the Injen upper and intake did it fit good?
How do you have it routed to the IC
Old Feb 26, 2007 | 02:19 PM
  #225
GREDDY's Avatar
So it's pretty safe to say this intercooler is better then the stock intercooler? Will it perform and cool better then stock? Who wants to donate to my fund (dyno time: about $70 an hour), I will buy this intercooler and do a before dyno (stock intercooler) and after (ebay intercooler) dyno test. This should put an end to all this bickering.......
