Car loss of power
Car loss of power
I been running 100oct for 5 times in a row until recenlty my car doesnt drive as fastmore. The gas is 100unleaded and I also changed the splark plugs to BR8ES and the idle is uncomfortable without ac turned on. Based on this, are the injectors fooked? or the o2 sensors?
Might be the gap on the spark plugs. I noticed a loss in performance when I replaced my stock plugs with some aftermarket ones and also spark them to the wrong specs. I fixed the gap but the car still feels slower than before....
Originally Posted by hkfeet
Yea Im going to have some BPR7EIX and see whats up tomorrow then.
My experience is that the BPR8ES work for me when on 116oct and 24-25psi at the drag strip in full out drag mode, but then when tuned back down to 93oct and 21psi, they don't work well at all, so I put my stock 7 series iridiums back in for daily driving...
Three things.
1. You sound like you may have a boost leak.
2. If it is truely unleaded it won't affect the O2 sensor.
3. What is your engine management consist of?
If it is stock ECU only then the 100 is your learned fuel after so many tanks. If you dropped back down to 93 then the ecu is possibly pulling timing because it needs to relearn the fuel. Try reseting the ECU.
tlclee
71
Dec 1, 2006 08:13 PM
