What reduces turbo lag?
Old Sep 17, 2005 | 07:01 AM
AC556k's Avatar
Three days into this turbo thing and I am still not used to it. What mods will reduce the initial turbo lag?
Thanks Dean
Old Sep 17, 2005 | 07:11 AM
Kwman's Avatar
Anti-Lag.
Larger downpipe, Free flowing intake, more aggressive tune, basically anything that (using common sense and a basic knowledge of physics) anything that would make a fast spinning wheel that moves air, move air faster with less back pressure.
Old Sep 17, 2005 | 07:15 AM
BoostWhore's Avatar
TB exaust, Flash, drop in filter, boost controller
Old Sep 17, 2005 | 07:23 AM
Chris@nolimitmotors's Avatar
eliminating the stock mass air flow sensor helps alot.
Old Sep 17, 2005 | 07:27 AM
pinoy9260's Avatar
a turbo lag reducer
Old Sep 17, 2005 | 07:30 AM
savageevo's Avatar
2.3 stroker
Old Sep 17, 2005 | 07:36 AM
EMR8's Avatar
Nitrous Oxide Systems! <I dont have one BTW
Old Sep 17, 2005 | 07:43 AM
Carbonics's Avatar
there's alot. Just to name a few, turbo back and intake. those are most common
Old Sep 17, 2005 | 07:47 AM
KTT's Avatar
KTT
Lag
The problem, at least for me, is that once you add a mod the car gets better... faster, more responsive (less lag) you want more and more. I'd recommend you start w/ a MBC and gauge, then intake and exhaust, the intercooler pipes. All make better flow and less lag...
Old Sep 17, 2005 | 07:54 AM
VTECH8TR's Avatar
I HIGHLY reccomend the Buschur path. If you need HELP i live down the street from you and i work on alot of local evos.
Old Sep 17, 2005 | 08:17 AM
import111's Avatar
I vote turboback exhaust and a custom tune. That can reduce lag a lot, and make better power.
Old Sep 17, 2005 | 08:38 AM
KTT's Avatar
KTT
I second the buschur notion...
Old Sep 17, 2005 | 08:41 AM
Kwman's Avatar
Anything buschur will take you where you want to go.
Old Sep 17, 2005 | 10:23 AM
pinoy9260's Avatar
get a B16 swap
Old Sep 17, 2005 | 12:09 PM
AWDrift07's Avatar
Originally Posted by pinoy9260
get a B16 swap
no way the k20 is a hundred times better
Seriously like everyone else said: tbe, mbc, reflash, intake, intercooler piping... talk to buschur
jameswwt
Dec 16, 2010 12:27 AM
dsm25psi
15
Jan 2, 2008 03:20 PM
nianlala
Apr 22, 2007 09:32 AM
Max Speed
Mar 13, 2006 06:03 PM
plokivos
45
Jul 19, 2005 11:09 AM
