engine blew cause of failed alky kit?
Old Nov 19, 2005 | 08:00 AM
  #31
SeanJhn9's Avatar
i just ordered an SMC kit, and have an aem ems....now how would i go about hooking it up to the ems, and would i still have use for the so called "controller" even though i've got an ems? thanks
Old Nov 19, 2005 | 08:04 AM
  #32
marks03evo's Avatar
Originally Posted by Ultimate CC
A little bird told me that SMC has a boost cut (fail safe) coming out in the very near future.
haha that would be great...I may wait to purchase a kit until they add this
Old Nov 19, 2005 | 08:34 AM
  #33
SlowCar's Avatar
Originally Posted by yesevo
dont be afraid using alky kit ! u not blow engine up even it got failed at 25psi./ buschure proved it already on this
Old Nov 19, 2005 | 08:18 PM
  #34
GTVEVO's Avatar
If you want a failsafe that works with the SMC kit here ya go. You need to AEM to use it though.
https://www.evolutionm.net/forums/sh...d.php?t=151383
The Alky control kit is currently being worked so it will be able to use this as well in the future correctly as well.
Enjoy.
Old Nov 20, 2005 | 07:09 AM
  #35
EvilBlueEvo8's Avatar
Originally Posted by MalibuJack
In my case, I have a relay that would interrupt the signal to the solenoid causing it to go to wastegate pressure if the fault light came on.. Not every kit has a aux output to use for an indicator lamp (or for the purpose I stated) but thats what I would use.
So how did you wire up the relay? I mean what wires to what terminals on the relay?
Old Nov 20, 2005 | 07:24 AM
  #36
smokedmustang's Avatar
No problems here! I was driving it without a voltage regulator (required) with my setup. and was having flooding issues, popping problems etc... now it works, and I have a "street-tune". so far, so good! But those who know my luck, know this could be temporary!
Old Dec 12, 2005 | 06:12 AM
  #37
TTP Engineering's Avatar
FAILSAFE: Was finally able to put a video together of the TTP-Engineering meth kit in action. The video was a demonstration of how our system reacts in the case of power failure. There is a lot of talk about failsafes and meth injection. I have not "seen" any documentation or proof that anyone else has actually made it work. Here is ours...
http://72.41.83.159/video/TTP.Meth.F...Safeguards.wmv
Here is a log of the a/f and boost and reaction to these parameters as we shut off the meth pump at 29psi. :dist: This is the point where most motors go "pop".
Old Dec 12, 2005 | 07:32 AM
  #38
Derek888's Avatar
i cant find the video link.... is there one? lol
2006EvoIXer
58
Jul 9, 2017 09:43 AM
BakoEvo
19
May 5, 2017 03:16 PM
scheides
10
Jul 14, 2008 10:58 AM
Derek888
31
Nov 3, 2005 02:36 AM
David Buschur
Sep 15, 2005 08:00 PM
