Tilton Clutch Install
Old Dec 4, 2005 | 03:53 PM
  #76
BADEVO's Avatar
Can anyone show these "lines" that required fittings etc?
  #77
joeymia's Avatar
Originally Posted by TTP Engineering
You can't have your idle that high. You will throw P0507 idle higher than expected. Let me know if your tip in issue is from 0-100kpa and I can help you. Bailey Engineering and I came up with a fix in the latest beta test update.
i am running no enrichment on map or tps. i have 0 problems now. my car is constantly throwing codes it doesn't bother me
Old Dec 4, 2005 | 03:58 PM
  #78
TTP Engineering's Avatar
http://www.ttp-engineering.com/Tilton.pdf
Page 2 in .pdf format.
Old Dec 4, 2005 | 04:00 PM
  #79
BADEVO's Avatar
Another quick question, I noticed you mentioned drilling a hole in your tranny... if you dont how do you run the lines.
Old Dec 4, 2005 | 04:11 PM
  #80
joeymia's Avatar
You can't have your idle that high. You will throw P0507 idle higher than expected. Let me know if your tip in issue is from 0-100kpa and I can help you. Bailey Engineering and I came up with a fix for tip in driveability in the latest beta test update.
http://72.41.83.159/video/tipin-maftpro.wmv
Early in the day with the .40 enrichment and bad plugs the car would stall if i did that.
Old Dec 4, 2005 | 04:14 PM
  #81
joeymia's Avatar
you run them out of the boot on the tranny like in this picture:
I drilled a hole for the bleed line so it would not bend downward. If the bleed line went thru the boot it would have bent. I figured it easier to bleed the way I did it.
Old Dec 4, 2005 | 05:42 PM
  #82
I hear you. There is an added throttle body size adjustment added under setup in the newest version firmware that cured the bog.
Old Dec 4, 2005 | 06:31 PM
  #83
TrinaBabe's Avatar
It just sounds like a DSM with a fidanza Youll get used to the incredibly quick engagement within a few days. Then its fun because anyone else that tries to drive it will stall it ten times trying to move it. Ill let you know how the Quartermasters one is. They look incredibly similair (Same type TOB, etc..).
Old Dec 4, 2005 | 06:33 PM
  #84
joeymia's Avatar
Yeah I had my dad drive it and he stalled a ton of times pulling out of the driveway
Old Dec 6, 2005 | 06:32 AM
  #85
Jack @ EvoStore's Avatar
Thanks for the excellent detailed, honest, real-world feedback, Joey. We had taken pictures during our install, but they ended up getting deleted off of the camera before they were uploaded.
I have talked to our main contact at Tilton and as soon as I get another car through here, we will get measurements on the two lines and Tilton will start making them as seperate pieces. Traditionally, as Scott said, their stuff is much more racer oriented. They give extra line because some people may want to route it differently, some may prefer a different length, some may not be using the motor the clutch is designed for in a production application, etc.
However, I pointed out that these clutches are going to a slightly different demographic and the street guys will have much less experience working with SS lines. He said it wouldn't be a problem, as long as everyone agreed on the length. It didn't even come up during our last install because our techs have been cutting the line for the Supra installs for a few years now.
And tell your dad not to feel too bad - I've stalled a few Tilton cars myself. Actually, after driving around in a client's hybrid-equipped car yesterday - I couldn't believe how much... "slower" and "sluggish" a stock clutch equipped car felt.
Old Dec 6, 2005 | 06:38 AM
  #86
BADEVO's Avatar
What do you guys charge to install a tilton in an EVO?
Old Dec 6, 2005 | 06:41 AM
  #87
We get them done for $500 on the Tiltons which includes the work currently needed with the ss braided line. PM me if you are ever in need of scheduling such a job.
Old Dec 6, 2005 | 06:46 AM
  #88
BADEVO's Avatar
Where are you located???
Old Dec 6, 2005 | 06:49 AM
  #89
GregGSC's Avatar
Scott is in Orlando, and does some nice work i might add.
Greg
Old Dec 6, 2005 | 06:52 AM
  #90
BADEVO's Avatar
Greg,
You guys doing Tilton installs over at GSC ???
