PLEASE look inside!! Motor problem that i cant figure out
Old Dec 3, 2005 | 12:40 PM
wprettyboy's Avatar
Was going to work today and my car just cut off (2003 mits Evo). I pulled to the side of the road to take alook but it would not even try to start. Didnt hear anything break but not saying it didnt. It turns over but it doesnt turn as freely as normal!! here is what i have troubleshooted so far....
New battery
checked fuel pump
getting spark
checked the bolt on the exh cam that sometimes comes loose
check engine fuses
check connections
PLEASE HELP if you have any ideas for me to try!!
Pics on post #40 and #43
Old Dec 3, 2005 | 12:51 PM
elhalisf's Avatar
get a breaker bar with a half inch drive, and see if you can spin the crank freely. make sure the car is in neutral.
also, get a compression tester and do a compression test.
do u have cams or cam gears? it might have skipped. a compression test will tell u that.
Old Dec 3, 2005 | 01:21 PM
wprettyboy's Avatar
crank.. with belt off right
i have cams, stock gears
i have a lightened crank pulley that is underdriven could that have made it skip?
Old Dec 3, 2005 | 01:27 PM
platinumspecv's Avatar
see if ur timing marks line up - and check ur plugs. CHeck compression....If timing skipped man - its bad... really hope u didnt bend some valves
Old Dec 3, 2005 | 01:58 PM
Ultimate CC's Avatar
Check something like fuses, do you happen to have a mechanical 02 fix?
Old Dec 3, 2005 | 02:01 PM
wprettyboy's Avatar
I have the two non fouler o2 fix!!!
Old Dec 3, 2005 | 02:02 PM
Thats your problem
Old Dec 3, 2005 | 02:03 PM
Go check your engine fuse and replace that, then go under the car and electrical tape the 02 sensor where you grounded it out, then take a mallet and bang the area around it so that way it doesn't rub. Problem solved. Now you can sleep tonite haha.
Old Dec 3, 2005 | 02:08 PM
wprettyboy's Avatar
i will try that but i check the engine fuse and it was fine. there was two and both were still good. i will replace them anyway to make sure. i will look at the o2 aswell
please keep the ideas coming, i will try anything. its my daily driver so i need it running!!!
Old Dec 3, 2005 | 02:10 PM
Yea I will let you know if I think of anything else
Old Dec 3, 2005 | 03:36 PM
wprettyboy's Avatar
the o2 sensor wasnt touching anything, all the fuses are fine!!
it tried to fire once but only for a slip second.
Old Dec 3, 2005 | 03:38 PM
hmmm, do you have cams gears, could have you possibly stripped a tooth or something.
Old Dec 3, 2005 | 03:39 PM
Bro check if your timing slipped.....do a compression test - if timing slipped you will have valves leaking and that will tell. Do it asap
Old Dec 3, 2005 | 03:40 PM
wprettyboy's Avatar
i have stock cam gears. im going to put the crank at TDC and see if they are correct. be back in a few.
anymore ideas from anybody please!!
Old Dec 3, 2005 | 03:41 PM
Yea the more I think about it is sounds like something to do with timing if its not any of the obvious things mentioned already.
