Help Broke the spring bolt on downpipe
Old Dec 13, 2005 | 02:32 PM
AcA's Avatar
AcA
IT is near freezing here and i decided to put my turbo back on. Everything went smoothly but I tighten the spring too tight and broke the bolt. Now the bolt is stuck on o2 housing. I haven't started the car yet because still have work to do on o2 sensor wires. (Ultimate racing test pipe)
I know it will leak but will it damage my donut gasket while driving until i get that bolt out and replaced?
Would a shop be able to take the bolt out?
Old Dec 13, 2005 | 02:36 PM
levo2nr's Avatar
there is a tool to take out broken bolts/stubs
something extracter i believe ...
anyhow snapon or even pepboys and autozone have them
i have a snapon set it works great
hope that help u
good luck
Old Dec 13, 2005 | 02:44 PM
AcA's Avatar
AcA
how much are they and would it be able to extract high grade stud? I got myself into alot of ****...Anyone with estimate how much a shop will charge to take that out?
Old Dec 13, 2005 | 02:52 PM
Juiced's Avatar
Do you have any sort of hi power drill our air tools?
If tou do go buy a easy out system from sears or where ever. the easyouts can drill into and remove grade 8 bolts with no problem, i've have to do it a few times on diffrent projects.
Or you can just drill it out and re tap it. eaither way it;s up to you and shouldt be that hard.
i also like the dremel cutting wheel to cut a slot in the bolt and just use a flat head to turn it out.
Good Luck.
Old Dec 13, 2005 | 02:57 PM
levo2nr's Avatar
snapon have diff sets that they sell i got mines for like 70.
it should work. but the think is. it will take a long time to take that
out when u have to work lying down on ur back and under ur car
unless u take or o2 housing out of ur car .
i dont know maybe there r shops that will do that .
Old Dec 14, 2005 | 06:30 AM
AcA's Avatar
AcA
anyone try these from ebay? any review these look same as helix
click here
Old Dec 14, 2005 | 10:59 AM
05SilverEvoVIII's Avatar
Good Luck.
Had horrible luck with this probably just going to end up drilling and tapping!
Old Dec 14, 2005 | 11:39 AM
bacalhau16's Avatar
i had the same problem about two weeks ago. I just drilled the bolt out with a good drill and drill bit, spray the bolt often with wd-40 to cool off the bit. It didnt take me more then 5 minutes really. I then just used a nut and bolt to refasten the dp to the o2 housing. I had to buy a curved wrench though to hold the nut while i fasten the bolt.
good luck! its really not hard though!
Old Dec 14, 2005 | 03:12 PM
AcA's Avatar
AcA
So it would be piece a cake for a decent shop right? I ordered another spring bolt so I'll be going to a shop. Is it nessesary to take the undertray? If so I will take it down myself before I get raped in labor.
Old Dec 14, 2005 | 08:01 PM
bacalhau16's Avatar
i have to take off my undertray to get to my dp. You could just try doing it urself and save a lot of money.
Old Dec 14, 2005 | 08:07 PM
Ev0ikon's Avatar
I don't see how one can work on the turbo and the o2 housing without removing the undertray.
Old Dec 14, 2005 | 08:56 PM
Fireball's Avatar
It's pretty common. There's even a HowTo in the HowTo section on how to do this.
nhsean69
11
Nov 14, 2013 03:57 PM
spooln3
Northwest Region
19
Aug 17, 2011 10:11 AM
Dmego4
Sep 24, 2010 10:31 AM
pulley1fan
Jun 23, 2007 11:04 AM
wprettyboy
Nov 22, 2004 03:43 PM
